[postgis-users] Various ways to handle addresses in postgresql
Shaozhong SHI
shishaozhong at gmail.com
Sun Apr 26 05:09:38 PDT 2020
Hi, Steve,
Thanks.
2 questions.
1. How can we remove things like Room 2a, Buildings 2-6b and etc with
regexp replace?
2. Once extensions created, can these functions be adapted? Are codes
available ? I will see whether to put it into a project, so that our
programmers can have work to do.
Regards,
Shao
On Sun, 26 Apr 2020 at 03:09, Stephen Woodbridge <
stephenwoodbridge37 at gmail.com> wrote:
> On 4/25/2020 7:19 PM, Shaozhong SHI wrote:
> > Hi, Steve,
> > Many thanks. Please send me the link to parse_address() and
> > standardize_address().
> If you already have postGIS installed then
> create extension address_standardizer;
> # \df parse_address
> List of functions
> Schema | Name | Result data type | Argument data types | Type
> public | parse_address | record | text, OUT num text, OUT
> street text, OUT street2 text, OUT address1 text, OUT city text, OUT
> state text, OUT zip text, OUT zipplus text, OUT country text | normal
> (1 row)
> # select * from parse_address('123-2 main street city ny');
> num | street | street2 | address1 | city | state | zip
> | zipplus | country
> 123-2 | main street | | 123-2 main street | city | NY |
> | | US
> (1 row)
> # \df standardize*
> List of functions
> public | standardize_address | stdaddr | lextab text, gaztab
> text, rultab text, address text | normal
> text, rultab text, micro text, macro text | normal
> You need tables for the lexicon, gazetteer, and rules, which should be
> included in the extension but I'm not seeing them. So you can grab these
> from:
> https://raw.githubusercontent.com/woodbri/imaptools.com/master/sql-scripts/geocoder/us-gaz.sql
> https://raw.githubusercontent.com/woodbri/imaptools.com/master/sql-scripts/geocoder/us-lex.sql
> https://raw.githubusercontent.com/woodbri/imaptools.com/master/sql-scripts/geocoder/us-rules.sql
> and load them like:
> psql mydb -f us-gaz.sql
> psql mydb -f us-lex.sql
> psql mydb -f us-rules.sql
> # select * from standardize_address('lex', 'gaz', 'rules', '123-2 main
> street city ny');
> building | house_num | predir | qual | pretype | name | suftype |
> sufdir | ruralroute | extra | city | state | country | postcode | box
> | unit
> | 123 | | | | 2 MAIN | STREET
> | | | | CITY | NEW YORK | USA | | |
> (1 row)
> This is a good example of why parsing addresses is so difficult. The
> rules for standardize_address do not account for a house number like
> "123-2", but the regexp in parse_address do handle it. It is easy to get
> the 80% right and very hard to get it much above that.
> -Steve
> > I need to find these first before test-running.
> > Regards,
> > Shao
> > On Sat, 25 Apr 2020 at 21:20, Stephen Woodbridge
> > <stephenwoodbridge37 at gmail.com <mailto:stephenwoodbridge37 at gmail.com>>
> > wrote:
> > Shao,
> > '^( *Building *[0-9]+)?[- 0-9]*'
> > or something like that should do it. But I think you will find that a
> > more robust solution is to use parse_address() and/or
> > standardize_address() as they will recognize a lot of other address
> > constructs, like "apt 3a" for for example.
> > parse_address() that a text field and breaks it into "house number
> > street name" and "city state zip", but only works well in North
> > America.
> > standardize_address() that comes with postGIS, breaks the address
> > down
> > into its components and can separate out things like buildings, and
> > apartment/unit specifiers so you can then take the fields you are
> > interested in and recombine just them in a new string. Again, this
> > works
> > best in North America.
> > My github address-standardizer is built to recognize address for most
> > counties, but it can also be configured to recognize address
> > standards
> > for any county without too much effort. It compiles and installs as
> > postgresql extension.
> > Addresses are generally very messy and unless your addresses are vary
> > simple you will be constantly fighting with this or that exception.
> > -Steve
> > On 4/25/2020 2:55 PM, Shaozhong SHI wrote:
> > > Is there a way to left trim including the building and number?
> > > Building 3 21-1 Great Avenue, a city, a country, this
> > > planet.
> > > How to take way those things which are too local to an address?
> > > Regards,
> > > Shao
> > > On Sat, 25 Apr 2020 at 01:48, Shaozhong SHI
> > <shishaozhong at gmail.com <mailto:shishaozhong at gmail.com>
> > > <mailto:shishaozhong at gmail.com <mailto:shishaozhong at gmail.com>>>
> > wrote:
> > > I find this is a simple, but important question.
> > > How best to split numbers and the rest of address?
> > > For instance, one tricky one is as follows:
> > > 21-1 Great Avenue, a city, a country, this planet
> > > How to turn this into the following:
> > > column 1, column 2
> planet
> > > Note: there is a hyphen in 21-1
> > > Any clue?
> > > Regards,
> > > Shao
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at lists.osgeo.org <mailto:
> postgis-users at lists.osgeo.org>
> > > https://lists.osgeo.org/mailman/listinfo/postgis-users
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200426/e8642517/attachment.html>
