[postgis-users] geometry type issue
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Mon Apr 27 05:18:50 PDT 2020
(not tested !!)
UPDATE a_table AS a SET a.geom = b.cgeom from (select name,
ST_ConcaveHull(ST_Collect(geom), 0.99) as cgeom from b_table group by
name having count(*) >= 3) AS b WHERE a.name = b.name
the "count(*) >= 3" removes point collections which will result in
degenerative concave hulls
Den 27-04-2020 kl. 12:29 skrev Shaozhong SHI:
> I added a new column.
> alter table a_table add column geom geometry(Polygon, 27700);
> Then,
> update a_table set geom = (select ST_ConcaveHull(ST_Collect(geom),
> 0.99) from b_table where name = _name) where name = _name;
> It kept throwing up an error message saying: "geometry type point does
> not match polygon".
> I thought that a concavehyll is a polygon. That is why I created a
> polygon column for it.
> Can anyone help?
> Regards,
> Shao
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200427/cc37e76b/attachment.html>
