[postgis-users] Find LineString segment index containing closest point?
Martin Davis
mtnclimb at gmail.com
Tue Aug 4 14:53:05 PDT 2020
And adding a ST_DumpSegments function would help make this (and other uses
cases) simpler as well.
On Tue, Aug 4, 2020 at 2:51 PM Martin Davis <mtnclimb at gmail.com> wrote:
> Good find. And yes, the only approach currently that seems viable is to
> iterate over the segments in some way and select the closest.
> Nowadays using LATERAL JOIN might make this a bit simpler.
> On Tue, Aug 4, 2020 at 1:43 PM Bruce Rindahl <bruce.rindahl at gmail.com>
> wrote:
>> I found this post from a few years back by Paul Ramsey:
>> http://blog.cleverelephant.ca/2015/02/breaking-linestring-into-segments.html
>> One of the examples gives a collection of each segment of the line along
>> with what you can use as an index. Could you then query for the closest
>> geometry from that collection and get the index number?
>> Sorry, I can't test right now as my pgadmin is not working.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200804/04982bbe/attachment.html>
