[postgis-users] Ideas for 3D snapping for linestrings
Alexandre Neto
senhor.neto at gmail.com
Tue Aug 11 18:42:35 PDT 2020
In the past I have successfully been able to fix linestring topology
problems (undershoots and overshoots) by using the following approach:
- identify startpoints and endpoints closer to another line less than a
given distance;
- determine the closest point to that other line;
- use a collection of closest points as input to ST_snap, to force the
lines to pass on those points.
This works fine for 2D linestrings, but know I need to make the Z values of
those touching vertexes also match. If I am not wrong, ST_snap only works
for 2D, Any ideas of how to assign the same Z to vertexes that have the
same XY?
Thanks,
Alexandre Neto
Now, I also need to do it in 3D, any
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200812/6ef447f0/attachment.html>
