[postgis-users] ST_Buffer malfunction on LINESTRING
Michal Seidl michal.seidl at gmail.com
Wed Aug 26 02:58:21 PDT 2020
Hello,
I am facing this malfunction of ST_Buffer. The result of closed
LINESTRING buffer should be polygon with hole but regular polygon is
returned?
I am using:
POSTGIS="2.1.4 r12966" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
LIBJSON="UNKNOWN" RASTER
This is the case
ST_AsText(ST_Buffer(ST_GeomFromText('LINESTRING(-632707.74
-1143841.28,-632728.28 -1143828.04,-632761.31 -1143818.48,-632747.42
-1143835.92,-632727.41 -1143861.05,-632687.29 -1143893.42,-632587.04
-1143963.89,-632469.61 -1144047.39,-632439.8 -1144068.97,-632426.45
-1144083.11,-632422.85 -1144089.95,-632423.07 -1144099.75,-632426.7
-1144107.51,-632427.54 -1144108.41,-632426.4 -1144109.46,-632425.57
-1144108.56,-632411.95 -1144094.85,-632403.98 -1144087.66,-632393.94
-1144079.17,-632371.19 -1144059.68,-632381.11 -1144052.77,-632398.98
-1144062.1,-632407.15 -1144063.46,-632420.6 -1144058,-632457.53
-1144030.85,-632521.98 -1143975.36,-632585.23 -1143928.05,-632634.76
-1143892.41,-632627.84 -1143886.95,-632631.46 -1143883.96,-632637.6
-1143889.98,-632684 -1143856.57,-632707.74 -1143841.28)'), 0.001)) AS
wkt_geometry
If I enlarge buffer distance to 0.01 result looks OK. Also if I change
from default propeties to endcap=square join=miter helps?
Anu suggestions?
Thanks Michal S.
