[postgis-users] St_Extrude
Regina Obe lr at pcorp.us
Wed Dec 9 15:01:04 PST 2020
Yes. Here is an example that uses two contrived tables  -  I'm joining by id
here, but you can just as well join by ST_Intersects  like if your elev is
from a raster and z is the pixel value when you do a ST_DumpAsPolygons
WITH elev AS ( SELECT id, z FROM generate_series(1,10,4) WITH ORDINALITY AS
f(z,id) )
  , poly AS (  SELECT id, geom
                                         FROM (VALUES (  1, ST_Buffer(
ST_Point(1,2), 10) ) ,
                    (  2, ST_GeomFromText('POLYGON((0 0 8, 0 1 8, 1 1 8, 1 0
8, 0 0 8))')  ) ) AS f(id, geom)
SELECT poly.id, ST_Extrude(poly.geom,0,0, elev.z)
FROM elev INNER JOIN poly ON (elev.id = poly.id);
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Amy O'Keefe
Sent: Wednesday, December 9, 2020 6:00 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: [postgis-users] St_Extrude
Hello,
Does anyone know if it is possible to extrude shapes to the assigned z
value?
So far I have only been able to use ST_Extrude to extrude the shapes to one
constant height
This email and any attachments are confidential and intended solely for the
use of the addressee and may contain information which is covered by legal,
professional or other privilege. If you have received this email in error
please notify the system manager at  <mailto:postmaster at ulster.ac.uk>
postmaster at ulster.ac.uk and delete this email immediately. Any views or
opinions expressed are solely those of the author and do not necessarily
represent those of Ulster University.
The University's computer systems may be monitored and communications
carried out on them may be recorded to secure the effective operation of the
system and for other lawful purposes. Ulster University does not guarantee
that this email or any attachments are free from viruses or 100% secure.
Unless expressly stated in the body of a separate attachment, the text of
email is not intended to form a binding contract. Correspondence to and from
the University may be subject to requests for disclosure by 3rd parties
under relevant legislation.
The Ulster University was founded by Royal Charter in 1984 and is registered
with company number RC000726 and VAT registered number GB672390524.The
primary contact address for Ulster University in Northern Ireland is Cromore
Road, Coleraine, Co. Londonderry BT52 1SA
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201209/72331141/attachment.html>
