[postgis-users] postgis-3.1.0beta1 released
Paul Ramsey
pramsey at cleverelephant.ca
Wed Dec 9 16:25:29 PST 2020
This is a beta1 release, for testing and quality assurance, to be followed shortly by a final release. If you're interested in the stability and usability of PostGIS, please take a little time to ensure that you can build and use this release.
https://download.osgeo.org/postgis/source/postgis-3.1.0beta1.tar.gz
https://postgis.net/2020/12/09/postgis-3.1.0beta1/
There have been a few changes since the alpha3 release.
* Breaking changes *
- #4214, Deprecated ST_Count(tablename,...), ST_ApproxCount(tablename, ...)
ST_SummaryStats(tablename, ..),
ST_Histogram(tablename, ...), ST_ApproxHistogram(tablename, ...),
ST_Quantile(tablename, ...), ST_ApproxQuantile(tablename, ...) removed.
(Darafei Praliaskouski)
* Enhancements *
- #4801, ST_ClusterKMeans supports weights in POINT[Z]M geometries (Darafei Praliaskouski)
- #4804, ST_ReducePrecision (GEOS 3.9+) allows valid precision reduction (Paul Ramsey)
- #4805, _ST_SortableHash exposed to work around parallel soring performance issue
in Postgres. If your table is huge, use ORDER BY _ST_SortableHash(geom)
instead of ORDER BY geom to make parallel sort faster (Darafei Praliaskouski)
- #4625, Correlation statistics now calculated.
Run ANALYZE for BRIN indexes to start kicking in.
- Fix axis order issue with urn:ogc:def:crs:EPSG in ST_GeomFromGML()
(Even Roualt)
