[postgis-users] postgis-3.1.0beta2 released
Marco Boeringa
marco at boeringa.demon.nl
Fri Dec 11 12:31:05 PST 2020
Hi Darafei,
Thanks for the added explanation, much appreciated.
Yes, it very much sounds like I ran into this particular issue. In my
specific case though, I was lucky enough to be able to workaround this
issue by modifying my SQL. The SQL used was a nested WITH structure that
creates a materialized view, and I had put the 'ORDER BY geom' clause on
the outer query. By moving the clause to the inner most CTE, which
directly referenced a table that did have a spatial index on the
geometry column, the processing time for the creation of the 370M
materialized view went down from an undetermined >30hours, to under 4
hours. This solved my particular issue.
I concur this sounds like needing a fix upstream.
Marco
Op 11-12-2020 om 20:53 schreef Darafei "Komяpa" Praliaskouski:
> Hello Marco,
> This is exactly the case. The way Postgres accelerates the sorting is
> by having a 8-byte "prefix" to sort on before sorting on the actual
> field content. There is a problem in parallel sort implementation in
> Postgres where this prefix (as which PostGIS uses the sortable hash
> which is Hilbert key currently) where this thing will get calculated
> in parallel workers, sorted, and then calculated again on the merge
> stage in main worker, and then sorted again. Since it's a relatively
> slow op to calculate it performance may degrade to
> single-thread-sort-like. To fight that, _ST_SortableHash is exposed
> for advanced users: it immutably emits the key as an integer and after
> the sort that integer can be passed from parallel workers to main
> worker to be used verbatim. Best practices around this are not
> established yet and your feedback is welcome.
> For what I've noticed for now there is a significant difference in
> speed if you do something along those lines:
> select _ST_SortableHash(geom), * from table order by 1;
> instead of
> select * from table order by _ST_SortableHash(geom);
> There may be other tricks to consider.
> Please note that the best way forward on this is to fix issue in
> upstream postgres instead of this workaround.
> On Fri, Dec 11, 2020 at 10:36 PM Marco Boeringa
> <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl>> wrote:
> Hi Paul,
> Could you potentially eleborate a bit about #4805, '_ST_SortableHash'
> exposed?
> I looked up the bug tracker issue, and have followed the links,
> but the
> information provided there is more of a stub, and at least one
> reference
> suggests mainly a link with BRIN type spatial indexes. On the other
> hand, it suggests a generic performance issue with Postgres and
> sorting
> very large spatial tables on the geometry column ('ORDER BY geom').
> I must admit I actually ran into to something that sounds like the
> latter, where attempting to 'ORDER BY geom' on a non-indexed spatial
> column of a >370M table, resulted in a relatively short (few hours)
> parallel execution of the query with multiple 'parallel workers'
> visible
> in pgAdmin, which was subsequently followed by > 30 hours of the
> 'client
> backend' doing single threaded work, with virtually no CPU, RAM or
> disk
> write activity. Since the database runs on SSD, this was unexpected.
> Even a full sequential scan of the entire table should only have
> cost a
> fraction of that time. I finally killed the process, not wanting
> to wait
> any longer.
> Marco Boeringa
> Op 11-12-2020 om 19:09 schreef Paul Ramsey:
> > Since there were a few quick additions to beta1, I have dropped
> a beta2. The next release will be rc1 and then final, barring any
> emergency.
> > * Enhancements *
> > - #4814, Do not drop empty geometry components when converting
> > to GEOS (Sandro Santilli)
> > - #4815, Fix GEOS conversion of POINT EMPTY to retain type
> > (Sandro Santilli)
> > - #4813, ST_MakeValid removing NaN coordinates (Sandro Santilli)
> >> On Dec 9, 2020, at 4:25 PM, Paul Ramsey
> <pramsey at cleverelephant.ca <mailto:pramsey at cleverelephant.ca>> wrote:
> >> This is a beta1 release, for testing and quality assurance, to
> be followed shortly by a final release. If you're interested in
> the stability and usability of PostGIS, please take a little time
> to ensure that you can build and use this release.
> https://download.osgeo.org/postgis/source/postgis-3.1.0beta1.tar.gz
> <https://download.osgeo.org/postgis/source/postgis-3.1.0beta1.tar.gz>
> >> https://postgis.net/2020/12/09/postgis-3.1.0beta1/
> <https://postgis.net/2020/12/09/postgis-3.1.0beta1/>
> >> There have been a few changes since the alpha3 release.
> >> * Breaking changes *
> >> - #4214, Deprecated ST_Count(tablename,...),
> ST_ApproxCount(tablename, ...)
> >> ST_SummaryStats(tablename, ..),
> >> ST_Histogram(tablename, ...),
> ST_ApproxHistogram(tablename, ...),
> >> ST_Quantile(tablename, ...),
> ST_ApproxQuantile(tablename, ...) removed.
> >> (Darafei Praliaskouski)
> >> * Enhancements *
> >> - #4801, ST_ClusterKMeans supports weights in POINT[Z]M
> geometries (Darafei Praliaskouski)
> >> - #4804, ST_ReducePrecision (GEOS 3.9+) allows valid
> precision reduction (Paul Ramsey)
> >> - #4805, _ST_SortableHash exposed to work around parallel
> soring performance issue
> >> in Postgres. If your table is huge, use ORDER BY
> >> instead of ORDER BY geom to make parallel sort
> faster (Darafei Praliaskouski)
> >> - #4625, Correlation statistics now calculated.
> >> Run ANALYZE for BRIN indexes to start kicking in.
> >> - Fix axis order issue with urn:ogc:def:crs:EPSG in
> ST_GeomFromGML()
> >> (Even Roualt)
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://lists.osgeo.org/mailman/listinfo/postgis-users>
> OSM BY Team - http://openstreetmap.by/ <http://openstreetmap.by/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201211/3e02ac87/attachment.html>
