[postgis-users] Upgrading PostGIS
Clifford Snow
clifford at snowandsnow.us
Mon Dec 21 09:59:13 PST 2020
Thanks for all the suggestions. I decided to take the safe route by running
pg_dumpall then turning on Postgresql 13 with Postgis 3.1. Once the data
was loaded the system was working perfectly.
I didn't mention this in my original email but one of my databases has
nealy 100M records. I didn't want to have to recreate it if I screwed up
the pg_upgrade path. pg_dumpall and reloading took a while but the end
result is a nice new postgresql server with the latest PostGIS.
Thanks again,
Clifford
On Thu, Dec 17, 2020 at 11:45 PM Tomas Straupis <tomasstraupis at gmail.com>
wrote:
> 2020-12-17, kt, 22:46 Clifford Snow rašė:
> > I want to upgrade Postgresql from 11 to 13 and PostGIS from 2.5 to 3.1
> on a Fedora Workstation. Is it possible?
> If I understand you correctly, you're using both postgresql and
> postgis packages from fedora repos?
> If so, these are my notes, I use Fedora:
> I've found it impossible to upgrade using only core packages,
> because if both postgre and postgis versions change, upgraded system
> is unusable (db upgrade fails), because you have to upgrade postgresql
> and during upgrade it needs access to both new and OLD versions of
> postgis libraries, and old libraries have to be compiled using all old
> libraries used in old postgresql. Therefore several years ago I
> switched to using core postgresql but postgis compiled from source.
> Now my notes on upgrading are:
> 1. BEFORE upgrading postgresql upgrade postgis to whatever newest
> version of postgis you want to use.
> 2. Make a copy of postgis/SFCGAL etc. libraries (.so files), for
> example everything from /usr/lib64/pgsql
> 3. vacuumdb -a -f -v
> 4. pg_dump (just to be on the safe side, but not mandatory)
> 5. Upgrade Fedora (and postgresql with it).
> 6. Copy the files you copied in step 2 to
> /usr/lib64/pgsql/postgres-XX/lib where XX - old version of postgresql
> you were upgrading from.
> 7. Compile postgis for the new upgraded postgresql
> 8. Upgrade the database
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
@osm_washington
www.snowandsnow.us
OpenStreetMap: Maps with a human touch
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201221/0b83f03a/attachment.html>
