[postgis-users] Changed intersection test speed after PG 11 -> 12 and PostGIS 2.5 -> 3 upgrade
Tom Kazimiers
tom at voodoo-arts.net
Sun Feb 2 21:00:34 PST 2020
Hi Regina and Paul,
On Sun, Feb 02, 2020 at 07:42:06PM -0800, Paul Ramsey wrote:
>> On Feb 2, 2020, at 7:37 PM, Regina Obe <lr at pcorp.us> wrote:
>> If it does, can you try changing the function to your old 11 definition and see if that makes the answers the same. Then at least we'll know it's the change in definition and can work from there.
Thanks for your replies. As far as I can tell, the definition I have for
ST_3DDWithin is the first version Regina posted (i.e. PostGIS 3.0):
# \df+ ST_3DDWithin
List of functions
Schema | Name | Result data type | Argument data types | Type | Volatility | Parallel | Owner | Security | Access privileges | Language | Source code | Description
public | st_3ddwithin | boolean | geom1 geometry, geom2 geometry, double precision | func | immutable | safe | postgres | invoker | | c | LWGEOM_dwithin3d |
For the sake of completeness, this is my exact PostGIS version in my Postgres
12.1 environment:
# select PostGIS_full_version();
postgis_full_version
POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 4.9.2, 08 September 2015" LIBXML="2.9.3" LIBJSON="0.11.99" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)"
With this and the default ST_3DDWithin version, my query plan is:
Limit (cost=32.79..230.14 rows=54 width=54) (actual time=193.840..202.393 rows=1569 loops=1)
Buffers: shared hit=14391
CTE bb_edge
-> Index Scan using treenode_edge_gix on treenode_edge te (cost=0.67..28.71 rows=1 width=16) (actual time=0.809..192.138 rows=1004 loops=1)
Index Cond: ((edge &&& '01020000800200000000000000F0C71C41000000007026144100000000C095034100000000F88D20410000000070B511410000000080940341'::geometry) AND (edge &&& st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision)))
Filter: ((project_id = 1) AND st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
Rows Removed by Filter: 5
Buffers: shared hit=6546
-> Nested Loop (cost=4.08..201.42 rows=54 width=54) (actual time=193.837..202.205 rows=1569 loops=1)
-> HashAggregate (cost=3.51..5.13 rows=54 width=8) (actual time=193.796..194.101 rows=1570 loops=1)
Group Key: bb_edge.id
-> Append (cost=0.00..3.38 rows=54 width=8) (actual time=0.817..193.016 rows=2060 loops=1)
-> CTE Scan on bb_edge (cost=0.00..0.06 rows=1 width=8) (actual time=0.816..192.664 rows=1004 loops=1)
-> CTE Scan on bb_edge bb_edge_1 (cost=0.00..0.06 rows=1 width=8) (actual time=0.002..0.130 rows=1004 loops=1)
-> ProjectSet (cost=0.00..0.83 rows=52 width=8) (actual time=0.008..0.015 rows=52 loops=1)
-> Result (cost=0.00..0.03 rows=1 width=0) (actual time=0.001..0.001 rows=1 loops=1)
-> Index Scan using treenode_id_pkey on treenode t1 (cost=0.56..3.60 rows=1 width=54) (actual time=0.004..0.004 rows=1 loops=1570)
Index Cond: (id = bb_edge.id)
Buffers: shared hit=7845
Planning Time: 1.211 ms
Execution Time: 202.791 ms
If I run it again, the query time drops by ~15ms. Once I apply the older
definition of ST_3DDWithin, I can't observer any other change in the timing.
The index condition does indeed change back to a version wihout the
st_expand(), but timing wise it doesn't seem to have any real effect:
Limit (cost=4483.06..4680.40 rows=54 width=54) (actual time=186.089..194.138 rows=1569 loops=1)
CTE bb_edge
-> Index Scan using treenode_edge_gix on treenode_edge te (cost=0.42..4478.98 rows=1 width=16) (actual time=0.880..184.426 rows=1004 loops=1)
Index Cond: (edge &&& '01020000800200000000000000F0C71C41000000007026144100000000C095034100000000F88D20410000000070B511410000000080940341'::geometry)
Filter: ((project_id = 1) AND (edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry) AND ('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry && st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
-> Nested Loop (cost=4.08..201.42 rows=54 width=54) (actual time=186.087..193.954 rows=1569 loops=1)
-> HashAggregate (cost=3.51..5.13 rows=54 width=8) (actual time=186.051..186.330 rows=1570 loops=1)
-> Append (cost=0.00..3.38 rows=54 width=8) (actual time=0.888..185.322 rows=2060 loops=1)
-> CTE Scan on bb_edge (cost=0.00..0.06 rows=1 width=8) (actual time=0.887..184.984 rows=1004 loops=1)
-> CTE Scan on bb_edge bb_edge_1 (cost=0.00..0.06 rows=1 width=8) (actual time=0.002..0.126 rows=1004 loops=1)
-> ProjectSet (cost=0.00..0.83 rows=52 width=8) (actual time=0.006..0.013 rows=52 loops=1)
Planning Time: 1.004 ms
Execution Time: 194.332 ms
And for comparison, this is the index scan in the 11/2.5 plan:
(cost=0.42..344.70 rows=1 width=16) (actual time=0.569..26.662 rows=1004 loops=1)
Filter: ((edge &&
000080940341'::geometry) AND (project_id = 1) AND
Buffers: shared hit=1616
To me it seems the index condition and the filter are the same now and
aren't actually the main source of the change.
>If this is the case, can you share your data or some mangled version
>that exhibits the same performance gradient change from 2.5 to 3? We’ll
>need something to profile to figure out where the extra time is going…
I think this should be possible, I try to find a small public example
data set where I can recreate this problem. The one I am working with
contains unpublished data and might be too big to transfer easily.
If you have any other ideas, I am happy to test them in the meantime.
Cheers,
Tom
