[postgis-users] ERROR: rt_raster_to_gdal: Could not create the output GDAL dataset
john polo jpolo at mail.usf.edu
Wed Feb 12 09:51:27 PST 2020
I am using PostgreSQL 12 and PostGIS 3 on Windows 10. I am using a
practice example for working with raster via psql. The values, like
"131072" are from the book, so I don't know exactly what they mean (or
much about the lo_ functions for that matter, other than they are meant
for large object processing):
SELECT oid, lowrite(lo_open(oid, 131072), img) As num_bytes
FROM (
     VALUES (
         lo_create(0),
         (SELECT
             ST_AsGDALRaster(ST_Band(rast,1),
             'USGSDEM',
             ARRAY[
                 'PRODUCER=' || quote_literal('postgis_in_action'),
                 'INTERNALNAME=' || quote_literal(rast_name)]
             ) As dem
         FROM ch07.bag_o_rasters
         WHERE rast_name = 'Raster 1 band heatmap')
) As v(oid,img);
I get the error:
"ERROR:  rt_raster_to_gdal: Could not create the output GDAL dataset"
I am connected to PostgreSQL:
postgis_in_action=# \conninfo
You are connected to database "postgis_in_action" as user "postgres" on
host "localhost" (address "::1") at port "5432".
and a simple SELECT for the row ID of the 'Raster 1 band heatmap' works.
I tried the same code in pgAdmin and got the same results. I searched
for solutions. I found something that said to check the GDAL settings:
postgis_in_action=# SELECT short_name FROM ST_GDALDrivers();
short_name
GTiff
AAIGrid
DTED
PNG
JPEG
GIF
USGSDEM
XYZ
(8 rows)
It seems that GDAL is set to produce a USGSDEM.
I don't know why I am getting the error. Can someone suggest how I fix
this, please?
best regards,
John Polo
Enlightenment is ego's ultimate disappointment.
-Chogyam Trungpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200212/caa26d26/attachment.html>
