[postgis-users] help with a SQL Command solved
paul.malm at lfv.se
paul.malm at lfv.se
Thu Feb 13 06:22:33 PST 2020
Sorry I found what was wrong;
Drop table if exists cutted;
CREATE TABLE "cutted" as WITH
blade AS (
SELECT ST_MakeLine(ST_SetSRID(ST_MakePoint(180, -90),4326),ST_SetSRID(ST_MakePoint(180.000, 90), 4326)) AS geom)
SELECT a.*, (ST_Dump(ST_Split(a.the_geom, b.geom))).geom FROM shifted AS a, blade AS b WHERE ST_Intersects(a.the_geom, b.geom)
UNION ALL
SELECT *, the_geom FROM shifted AS a WHERE NOT EXISTS (
SELECT 1 FROM blade AS b WHERE ST_Intersects(a.the_geom, b.geom)
ALTER TABLE cutted DROP COLUMN IF EXISTS the_geom;
ALTER TABLE cutted RENAME COLUMN geom TO the_geom;
Från: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] För Malm, Paul (Operations AIM)
Skickat: den 13 februari 2020 14:56
Till: postgis-users at lists.osgeo.org
Ämne: [postgis-users] help with a SQL Command
Hi list!
I have a problem with a sql command, I would be grateful if someone please could tell me what I'm doing wrong.
I have a polygon layer where some polygons exceeds the 180/-180 border.
I would like to cut the polygons with a line from 180,90 to 180,-90.
I've got this far:
blade AS (
UNION ALL
It cuts the exceeding polygons nice but the uncut objects are duplicated in the result layer (cutted).
Thanks,
[2_LFV_engelsk_96]
Paul Malm
Operations AIM
Direct +46 (0)8 797 70 23 Mobile: +46 (0)708 601115
paul.malm at lfv.se
Mail & Visit: Löjtnantsgatan 25, 115 50 Stockholm, Sweden
Unit phone: +46 (0)8 797 70 20
www.lfv.se<http://www.lfv.se/>
Please consider the enviroment before printing this e-mail message.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200213/6132a857/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200213/6132a857/attachment.jpg>
