[postgis-users] Performance Postgres12/Postgis3 vs Postgres10/Postgis2.4
Stefan Duling
stefan.duling at mapz.com
Wed Feb 19 02:37:20 PST 2020
Hi everyone,
at the moment I am trying out a new setup for our geo database server. Primarily I upgraded from Postgres and Postgis to newer versions. Beside of the memory both databases run on the same machine setups and contain identical data. Differences are:
OLD SETUP
16GB RAM
Postgres 10.12
Postgis 2.4
shared_buffers = 4GB
work_mem = 128MB
maintenance_work_mem = 1536MB
NEW SETUP
32GB RAM
Postgres 12.1
Postgis 3.0
shared_buffers = 6GB
work_mem = 256MB
maintenance_work_mem = 3GB
Sadly I observe several queries that take multiple times to execute with the new setup. While the most expensive query took ~10h on the old setup, nearly 3 days are needed on the new setup. Currently I am analysing a more lightweight query, that execution time doubled with the new setup.
Can someone help me with the EXPLAIN ANALYZE results? Is Postgres 12 / Postgis 3 slower in general? Is the use of parallel workers ineffective in my use case?
Thanks in advance!
Stefan Duling
OLD SETUP
EXPLAIN ANALYZE CREATE TABLE osm_admin_lines_split AS
SELECT osm_id, name, admin_level, name_en, name_fr, area, iso, is_in, ST_SubDivide(ST_Collect(ST_ExteriorRing(the_geom)),5000) AS geometry
FROM (SELECT osm_id, name, admin_level, name_en, name_fr, area, iso, is_in, (ST_Dump(geometry)).geom AS the_geom FROM osm_admin_areas) AS foo
GROUP BY osm_id, name, admin_level, name_en, name_fr, area, iso, is_in;
QUERY PLAN
ProjectSet (cost=274906731.77..3540274986.77 rows=616689000000 width=65) (actual time=97024.487..141100.410 rows=739733 loops=1)
-> GroupAggregate (cost=274906731.77..299574291.77 rows=616689000 width=65) (actual time=97024.476..118509.455 rows=611704 loops=1)
Group Key: osm_admin_areas.osm_id, osm_admin_areas.name, osm_admin_areas.admin_level, osm_admin_areas.name_en, osm_admin_areas.name_fr, osm_admin_areas.area, osm_admin_areas.iso, osm_admin_areas.is_in
-> Sort (cost=274906731.77..276448454.27 rows=616689000 width=65) (actual time=97024.431..108902.529 rows=708178 loops=1)
Sort Key: osm_admin_areas.osm_id, osm_admin_areas.name, osm_admin_areas.admin_level, osm_admin_areas.name_en, osm_admin_areas.name_fr, osm_admin_areas.area, osm_admin_areas.iso, osm_admin_areas.is_in
Sort Method: external merge Disk: 4087720kB
-> Result (cost=0.00..163888355.59 rows=616689000 width=65) (actual time=42.029..84168.985 rows=708178 loops=1)
-> ProjectSet (cost=0.00..3549215.58 rows=616689000 width=65) (actual time=42.019..83866.290 rows=708178 loops=1)
-> Seq Scan on osm_admin_areas (cost=0.00..308514.89 rows=616689 width=6931) (actual time=16.288..9536.779 rows=611707 loops=1)
Planning time: 0.364 ms
Execution time: 244169.613 ms
(11 rows)
NEW SETUP
EXPLAIN ANALYZE CREATE TABLE public.osm_admin_lines_split AS
QUERY PLAN
ProjectSet (cost=390996247.38..409798165.99 rows=620679000 width=65) (actual time=38272.152..512018.424 rows=750429 loops=1)
-> GroupAggregate (cost=390996247.38..391174692.59 rows=620679 width=65) (actual time=38272.119..58302.727 rows=611704 loops=1)
-> Sort (cost=390996247.38..390997799.08 rows=620679 width=65) (actual time=38272.021..46632.706 rows=708178 loops=1)
Sort Method: external merge Disk: 4087328kB
-> Gather (cost=1000.00..390930320.45 rows=620679 width=65) (actual time=1035.032..23429.953 rows=708178 loops=1)
Workers Planned: 4
Workers Launched: 4
-> Result (cost=0.00..390867252.55 rows=155170000 width=65) (actual time=817.294..20634.253 rows=141636 loops=5)
-> ProjectSet (cost=0.00..1390552.55 rows=155170000 width=65) (actual time=817.287..20546.850 rows=141636 loops=5)
-> Parallel Seq Scan on osm_admin_areas (cost=0.00..226001.70 rows=155170 width=6702) (actual time=0.381..3937.298 rows=122341 loops=5)
Planning Time: 13.173 ms
JIT:
Functions: 110
Options: Inlining true, Optimization true, Expressions true, Deforming true
Timing: Generation 27.663 ms, Inlining 580.814 ms, Optimization 2265.257 ms, Emission 1222.527 ms, Total 4096.260 ms
Execution Time: 629042.211 ms
(18 rows)
