[postgis-users] PostGIS on a shared hosting
Jeff Norville
jeff at jnorville.com
Fri Feb 21 01:17:49 PST 2020
Hi Zo,
Does O2Switch give you command line access to your postgresql instance
(psql)? I installed the combo on AWS a few years ago following the general
installation guides ... but you do need to verify the database version and
permissions to other standard directories to avoid surprises. For example
you don't technically need the GDAL libraries if you aren't working with
rasters - which reduces the installation footprint.
https://postgis.net/docs/postgis_installation.html#install_short_version
Bien à vous
Jeff
On Fri, Feb 21, 2020 at 9:39 AM Zo Razafindramanitra <zo.razafi at gmail.com>
wrote:
> Hello from Madagascar,
> I need help please. I'm on a shared hosting, on french O2SWTICH.
> Is there any way to install PostGIS under user /home/... and make it work
> as if it was installed through normal installation process? If so, how do I
> achieve that?
> Regards
> *Zo Razafindramanitra*
> Web & Mobile Engineer
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200221/1fb24cc8/attachment.html>
