[postgis-users] PostGIS 3.0.1 released
Marco Boeringa
marco at boeringa.demon.nl
Sat Feb 22 16:31:59 PST 2020
Minor typo, but the #4558 issue regarding oversimplification, is
actually ticket #4568:
https://trac.osgeo.org/postgis/ticket/4568
Marco
Op 22-2-2020 om 23:05 schreef Darafei "Komяpa" Praliaskouski:
> The PostGIS Team is pleased to release PostGIS 3.0.1.
> Best served with PostgreSQL 12.2, GEOS 3.8.0, SFCGAL 1.3.7, GDAL
> 3.0.4, PROJ 6.3.1, protobuf-c 1.3.3, json-c 0.13.1.
> source download https://download.osgeo.org/postgis/source/postgis-3.0.1.tar.gz
> NEWS https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.1/NEWS
> PDF docs en https://download.osgeo.org/postgis/docs/postgis-3.0.1.pdf
> This is the first stable release of PostGIS done after our move to Git
> and that supports PostgreSQL 13 development release.
> Details of this release can be found in NEWS file:
> https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.0.1/NEWS which
> is also included in source tar ball and in this email.
> If you come across any issues, feel free to report via our ticket
> tracker https://trac.osgeo.org/postgis or mailing list with details as
> described here - https://postgis.net/support/. For security issues,
> send reports to security at postgis.net.
> Breaking Changes
> #4637 svn number replaced by git hash in version output (Sandro
> Santilli, Regina Obe, Bas Couwenberg)
> New Features
> #4617, Add configure switch --without-phony-revision (Raúl Marín)
> Use to prevent postgis_revision.h from rebuilding (when building from
> tar ball) and building in a gitted folder.
> Bug Fixes and Enchantments
> #4558, Fix oversimplification of polygon inner rings (Raúl Marín)
> #4588, Fix update when ST_Union(geometry) doesn’t exist (Raúl Marín)
> #4590, Fix pgupgrade issue with STLineCrossingDirection (Raúl Marín)
> #4599, ST_AddPoint: Accept -1 as a valid position (Raúl Marín)
> #4600, Improve precision of ST_TileEnvelope (Raúl Marín)
> #4605, Fix postgis_upgrade.pl with PostgreSQL 12 (Matti Linnanvuori)
> #4606, Respect user’s LDFLAGS in postgis module build (Sandro Santilli)
> #4610, Add in logic to install postgistigergeocoder from unpackaged (Regina Obe)
> #4581, Installing postgis_raster from unpackaged tries to use wrong
> schema (Regina Obe)
> #4596, The script to generate nationscriptload.sh is missing a
> trailing quote (Bill Mill)
> #4608, PG12: Fix several bugs in the index support function (Raúl Marín)
> #4621, Prevent stack overflow when parsing WKB (Raúl Marín)
> #4626, Support pkg-config for libxml2 (Bas Couwenberg)
> #4632, Allow building with PostgreSQL 13 (Raúl Marín)
> #4570, Include raster2pgsql in windows packaging (Regina Obe)
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
