[postgis-users] Postgis Topology and slow topology.TopoGeo_addLinestring on big datasets
Lars Aksel Opsahl Lars.Opsahl at nibio.no
Wed Feb 26 03:34:12 PST 2020
Hi
>From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of Sandro Santilli <strk at kbt.io>
>Sent: Wednesday, February 26, 2020 12:19 PM
>To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>Subject: Re: [postgis-users] Postgis Topology and slow topology.TopoGeo_addLinestring on big datasets
>On Wed, Feb 26, 2020 at 11:10:36AM +0000, Lars Aksel Opsahl wrote:
>> Yes I can do that but then I have to remove this extra lines when done.
> > This should by able to do by checking if two faces that share edge belongs the same original polygon.
>Yes, it is a way.
>> If checkout this code "git fetch origin pull/28/head:batch-topo2" is any problem for me to compile this code and test it ?
>The code in that branch is broken, as shown by the bot
>building it, unfortunately.
>> Or do I have to do a lot changes in my own code to test it ?
>Yes, the code would also need to be changed, and won't be performant
>because that branch only touches ST_CreateTopoGeo, which needs to
>do everything at once (loading all in memory).
>--strk;
>_______________________________________________
>postgis-users mailing list
>https://lists.osgeo.org/mailman/listinfo/postgis-users
Ok Thanks again, I will maybe do a test using alternative one first then.
Lars
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200226/e8427e26/attachment.html>
