[postgis-users] Extract specific area by ROI polygon
klos
andreas.klos at fernuni-hagen.de
Mon Jan 6 08:51:50 PST 2020
Dear all Users and/or Participants of PostGIS,
I am working with a digital elevation point cloud (mean point desnity
4-10 pts/m², positional precision +/- 30 cm, height precision +/- 15 cm,
area: 1000x1000m). I interpolated a raster file with an resolution of 1m
x 1m. Further denoted as DEM.
Furthermore, I have a 4 channel, high-precision, orthographic picture
(mean positional precision is +/- 20-30 cm, horizontal resolution is
20cm x 20cm) for the same area. Further denoted as DOP
I stored both in a PostgreSQL-DB with PostGIS extension and a tiling
size of 40x40.
The target to create polygons and request raster data of both layers
mentioned above covered by those polygons.
I created a polygon with an extend of e.\,g. 32 x 32m. This polygon
become shifted over the area of interest, so that the whole area is
covered by many polygons.
Afterwards I created a query for the covered raster data:
WITH
ref AS(
SELECT
ST_Transform(rast,25832) AS align_to
FROM geodata.dsm LIMIT 1
aligned AS(
SELECT
ST_Union(
ST_Transform(
ST_Clip(
dsm.rast,
p.geom
align_to
) as rast1,
ST_Union(
ST_AsRaster(
p.geom,
align_to
) rast2
FROM
geodata.dsm AS dsm,
public.classification_result_overlap_35cm_ss8 AS p
CROSS JOIN ref
WHERE
p.gid=1 AND ST_Intersects(dsm.rast, p.geom)
SELECT
ST_MapAlgebra(rast1, rast2,'[rast1]') as raster FROM aligned;
After a visual inspection of the results, it became obvious, that the
mapping between the queried DEM and DOP is not 100% exact. It became
more evident, when I made the polygon size smaller, lets say 8 x 8m.
I queried with ST_GeoReference the upper left coordinates of the queried
DEM and DOP data and determined with pyproj.Geod(...).inv the distance
between the upper left coordinates. I figured out, that the shift
between the upper left coordinates of the DEM and DOP data ranges
between 0 and 1.2. Might it be, that I did something wrong within my
query? I thought maybe the max difference between DEM and DOP could
result through the different horizontal resolution of the datasets. In
this case, the maximum difference between the data could be \sqrt{2} m.
By the way, does someone have a hint for me, to further accelerate this
query?
System setting:
DB: PostgreSQL version 12.1
OS: Ubuntu 18.04
Extension: POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120"
GEOS="3.8.0-CAPI-1.13.1 " PROJ="6.3.0" GDAL="GDAL 3.1.0dev-437c92a187,
released 2020/01/05" LIBXML="2.9.9" LIBJSON="0.12.1" RASTER
Thanks in advance.
Best Regards
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200106/dd082257/attachment.html>
