[postgis-users] error: type "raster" does not exist
john polo
jpolo at mail.usf.edu
Mon Jan 13 17:54:50 PST 2020
I'm learning to use PostGIS with PostgreSQL by way of the book _PostGIS
In Action, 2ed_. I'm working in Windows 10. Using the following example
from the book:
CREATE TABLE ch02.my_rasters (
rid serial PRIMARY KEY,
name varchar(100),
rast raster);
I get the error in the subject line:
Searching for some help, I came across the note from
https://postgis.net/docs/manual-3.0/raster.html
"[Raster] Requires PostGIS be compiled with GDAL support. Currently
rasters can be implicitly converted to geometry type, but the conversion
returns the ST_ConvexHull
<https://postgis.net/docs/manual-3.0/RT_ST_ConvexHull.html> of the
raster. This auto casting may be removed in the near future so don't
rely on it."
I wasn't sure how to check PostGIS settings, but remembered that Ch.1 of
the book suggested to use
SELECT postgis_full_version();
And when I looked at the result from that the first time, I did not
notice that GDAL was missing. GDAL appeared to be installed, it was in
my system environment variables. I reinstalled PostGIS and the select
statement returns now:
POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="Rel. 5.2.0, September 15th, 2018" LIBXML="2.9.9" LIBJSON="0.12"
LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)"
When PostGIS installed, it requested to enable a couple of setting
regarding rasters and I said yes. Currently, the relevant (I think)
system variables are:
POSTGIS_ENABLE_OUTDB_RASTERS 1
POSTGIS_GDAL_ENABLED_DRIVERS GTiff PNG JPEG GIF XYZ DTED USGSDEM AAIGrid
GDAL_DATA C:\Program Files\PostgreSQL\12\gdal-data
I'm not sure why GDAL still doesn't register as part of the PostGIS
settings. I would appreciate help in trying to get PostGIS and GDAL to
work together for utilizing rasters.
best,
John
Enlightenment is ego's ultimate disappointment.
-Chogyam Trungpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200113/50b1494c/attachment.html>
