[postgis-users] pg_upgrade from postgresql 11 postgis 3 to postgresql 12 postgis 3
rmrodriguez at carto.com rmrodriguez at carto.com
Tue Jan 14 01:22:12 PST 2020
On Tue, Jan 14, 2020 at 10:08 AM Michal Zimmermann <
michal.zimmermann at gmtech.cz> wrote:
> Hi,
> I'm having an issue upgrading from postgresql 11 postgis 3 to postgresql
> 12 postgis 3 via pg_upgrade utility. That's because pg_constraint.consrc
> was removed in postgresql 12 [1]. Is it possible to do such upgrade or do I
> need to run pg_dumpall and upgrade semi-manually?
Can you confirm the dump comes from 3.0? Both 2.5.2 and 3.0 changed
`pg_constraint.consrc`
with `pg_get_constraintdef` so it shouldn't be complaining. You can check
the version in the SQL scripts with `Select postgis_full_version()`.
Regards,
Raúl Marín Rodríguez
carto.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200114/81359e58/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200114/81359e58/attachment.png>
