[postgis-users] Doubt about toTopoGeom tolerance
Alexandre Neto
senhor.neto at gmail.com
Wed Jul 1 12:21:27 PDT 2020
Ah, now I get what you want.
You want to fix undershoots and overshoots, right?
No, just topology snapping won't work, because it only snaps to vertexes.
Notice that the nearby edge also needs a vertex added in the closest point
to the end of line. Otherwise you will always have a topological error
there even if it's 0.000001 m.
I think I have a query for that somewhere. Some time ago I was planning to
do a blog post about it, but it never came out.
Let me see if I can find it.
Alexandre Neto
A quarta, 1/07/2020, 17:05, Alexandre Silva <amsilva at infoportugal.impresa.pt>
escreveu:
> Hi,
> Sorry, i didn't explain myself clearly. I have a node (that is the end of
> an edge) that is less than 0.1m from another edge. If i use a tolerance of
> 0.2m it doesn't snap but if i use 0.5m it snaps to a node of that edge.
> Shouldn't it snap to the closest point on that edge, which is within the
> tolerance?
> Thanks,
> Alexandre Silva
> *De:* postgis-users <postgis-users-bounces at lists.osgeo.org> em nome de
> Alexandre Neto <senhor.neto at gmail.com>
> *Enviado:* 1 de julho de 2020 16:42
> *Para:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Assunto:* Re: [postgis-users] Doubt about toTopoGeom tolerance
> Hi,
> I am not sure I understood your affirmation. wanting to snap to the
> nearest edge, its the same as using a very large tolerance.
> Alexandre Neto
> On Wed, Jul 1, 2020 at 3:47 PM Alexandre Silva <
> amsilva at infoportugal.impresa.pt> wrote:
> Hi,
> Thank you for your response.
> I tried the solution you provided and the result was the same, however
> after increasing the tolerance the geometry did indeed snap to a nearby
> node.
> I thought that the snap was to the closest point on a nearby edge but it
> seems that it only snaps to nodes within the tolerance. What's the best way
> to snap a geometry to the closest point on a nearby edge? I cannot increase
> the tolerance as it would be error prone (to make the snap on one specific
> geometry I had to increase it from 0.1m to 0.5m).
> Thank you for your assistance,
> Alexandre Silva
> *Enviado:* 29 de junho de 2020 23:49
> Hi,
> I have looked into the documentation, and it seems that there are two form
> of using toTopoGeom:
> 1. One to add new topogeometry an existing topology layer, and another to
> change an element. This is what you seem to be using.
> 2. The second form, with less arguments, is used ADD changes to existing
> topoGeometries. But, it says you may want to use clearTopoGeom(topo) to
> create a totally new shape.
> My gut feeling is that since you already have the topogeometry in the
> topology, when you try to add it again, it will snap to the old geometry
> any way.
> My first try would be something like:
> UPDATE lines_table
> SET topo = topology.toTopoGeom(geom, clearTopoGeom(topo), 0.1)
> WHERE id = 1263;
> http://postgis.net/docs/manual-dev/toTopoGeom.html
> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpostgis.net%2Fdocs%2Fmanual-dev%2FtoTopoGeom.html&data=02%7C01%7Camsilva%40infoportugal.impresa.pt%7C7867de8d4278456b17d908d81dd5620b%7Cd227b2e71c404f63b5132f3665c334e6%7C0%7C0%7C637292149594408975&sdata=8J6ubjm8WNgNA%2BqDe%2BZ1YJbEJrWjlycj7dYnjs0qhM0%3D&reserved=0>
> Good luck,
> Alexandre Neto
> On Mon, Jun 29, 2020 at 5:53 PM Alexandre Silva <
> Hi,
> I have trying using the topology to correct some data with marginal errors
> and in some particular cases i'd like to use a higher snap tolerance than
> the defined in the topology.
> The topology has a tolerance of 0.01m (using a metric projection) and some
> lines need an higher tolerance of 0.1m to be fixed. Here's the code i used
> to create the topology and to fix the particular cases:
> SELECT topology.CreateTopology('a_topology', 3763, 0.01, true);
> UPDATE lines_table
> SET topo = topology.toTopoGeom(geom, 'a_topology', 1, 0.1)
> WHERE id = 1263;
> Even though the line is closer than 0.1m to another line, it isn't
> snapped. Am i thinking wrong here? Shouldn't the line be snapped? Which of
> the tolerances prevails?
> If this is the expected behaviour is there a better way to do what i'm
> trying to do?
> Thanks in advance,
> Alexandre Silva
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fpostgis-users&data=02%7C01%7Camsilva%40infoportugal.impresa.pt%7C7867de8d4278456b17d908d81dd5620b%7Cd227b2e71c404f63b5132f3665c334e6%7C0%7C0%7C637292149594408975&sdata=c8otUEmfU76dwNXRpPxZzCqw4onRfC%2B7Ax%2BEV%2Fu43XI%3D&reserved=0>
> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fpostgis-users&data=02%7C01%7Camsilva%40infoportugal.impresa.pt%7C7867de8d4278456b17d908d81dd5620b%7Cd227b2e71c404f63b5132f3665c334e6%7C0%7C0%7C637292149594418969&sdata=1LfO1aB8VFc2lSS16TbXLnFZ%2BI3BO4YCkWb8JDULzQ0%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200701/03b7efce/attachment.html>
