[postgis-users] Fwd: type "geometry" does not exist, but it exists
pham lan
phamlankt at gmail.com
Thu Jul 2 09:36:09 PDT 2020
Hello all,
I would like to ask for your help in understanding a postgres issue that I
could not find out till now.
So I have a postgres dump file of 159G created by pg_dump that I want to
restore to my database. It is running well till it throws me the following
error:
$ psql -a -U postgres -d mydb <
/opt/postgres_restore_files/db_mydb_2020-06-11_18-00.dmp
CREATE INDEX
CREATE INDEX
CREATE INDEX
ERROR: type "geometry" does not exist
LINE 1: SELECT geog::geometry
QUERY: SELECT geog::geometry
CONTEXT: PL/pgSQL function public._togeom(public.geography) line 3 at RETURN
STATEMENT: CREATE INDEX my_index ON mydb.geo_zone USING gist
(public._togeom(geom));
CREATE INDEX
CREATE INDEX
CREATE INDEX
CREATE INDEX
I already looked and tried the comment on similar issue in the
following links but it does not help:
https://stackoverflow.com/questions/6850500/postgis-installation-type-geometry-does-not-exist
Below are the definitions:
CREATE FUNCTION public._togeom(geog public.geography) RETURNS public.geometry
LANGUAGE plpgsql IMMUTABLE
AS $$
BEGIN
RETURN geog::geometry;
END;
ALTER FUNCTION public._togeom(geog public.geography) OWNER TO postgres;
CREATE TABLE mydb.geo_zone (
geom public.geography,
ALTER TABLE mydb.geo_zone OWNER TO my_user;
CREATE INDEX my_index ON mydb.geo_zone USING gist (public._togeom(geom));
I can see type geometry exists in public schema after creating extension
postgis in mydb, not sure why it throws that error during the restore
procedure. Also I tried afterward to run the CREATE INDEX command again
manually and it works without any error and I can see the index "my_index"
created. But of course i don't want this manual fix, just try to understand
what causes the issue.
Any idea from you is highly appreciated! Thanks.
[image: image.png]
Best regards,
Lan Pham
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200702/a6aad649/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200702/a6aad649/attachment.png>
