[postgis-users] Fwd: st_union produces different result from st_memunion
Martin Davis mtnclimb at gmail.com
Thu Jul 9 07:34:25 PDT 2020
(Forwarding to PG User lisdt thread as well)
Good news - overlaying the full dataset works using JTS OverlayNG in
Snap-Rounding mode.  It completes in 195 s using a grid size of 1e-8 (which
is quite fine).
Interestingly it didn't complete when using OverlayNG with Snapping
noding (which is  heuristic-based noding strategy intended to preserve more
precision).  I'll have to look into that further.
Here's some instructions on how to run this in JTS:
- Clone the branch https://github.com/dr-jts/jts/tree/overlay-sr
- Build using maven clean install
- Run the TestBuilder (
https://github.com/locationtech/jts/blob/master/doc/JTSTestBuilder.md)
- Convert the SQL file to a WKB file by removing the SQL header and footer,
leaving only the WKB text
- Drop the WKB file onto the TestBuilder A input box to load it
- Run the geometry function OverlayNG/union with Grid Scale = 100000000
On Tue, Jul 7, 2020 at 10:49 PM Jonathan Schultz <jonathan at schultz.la>
wrote:
> Oh sorry about that. Here is a link to the file on my own VPS:
> http://barraqda.org/dbca_dump_116_35_117_34.zip
> I've been playing with JTS but it's a bit of a steep learning curve.
> Getting stuck on Java NoClassDefFoundError messages, I presume related to
> incompatible versions and such-like. I'd very much appreciate advice on
> running OverlayNG.
> Cheers,
> Jonathan
> On 8/7/20 1:41 pm, Martin Davis wrote:
> > That's interesting that ST_SnapToGrid doesn't help for the full dataset
> - but not totally surprising, since it's a pretty blunt instrument.
> > I'd like to try out the larger dataset.  That free download website
> seems to have a bunch of unpleasant strings attached though - is there any
> other way you can make the data available?
> > If you are able to run Java, by all means try OverlayNG.  Happy to
> provide advice on how to run it if needed.
> > cheers - Martin
> > On Tue, Jul 7, 2020 at 8:10 PM Jonathan Schultz <jonathan at schultz.la
> <mailto:jonathan at schultz.la>> wrote:
> >     Thank you for the prompt feedback.
> >     As you suggested I tried using ST_SnapToGrid and that worked very
> well even with a very fine grid - st_snaptogrid(geometry,0.000000000001).
> However when it came to a collection of lines more useful for real work
> (13540 records compared with 6 in the minimal dataset) I found that
> snapping even to a grid so coarse as to render the data useless -
> st_snaptogrid(geometry,0.01) - still produced an incorrect result.
> >     Here is the dump of my larger dataset:
> https://anonfiles.com/rdYcG1Edo2/dbca_dump_116_35_117_34_sql
> >     I'll have a go myself with OverlayNG.
> >     And I will file a PostGIS issue depending on the conclusions from
> this discussion.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200709/26e5af84/attachment.html>
