[postgis-users] Issue while installing Postgis3.0 version.
Regina Obe lr at pcorp.us
Mon Jul 13 08:48:20 PDT 2020
If you haven’t already – as the note says you need to install the postgresql development package.
If you are on yum, it’s usually something like
yum install postgresql-devel
or
yum install postgresql12-devel
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of purushotham reddy Patil
Sent: Monday, July 13, 2020 10:48 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Issue while installing Postgis3.0 version.
Hi Team,
I am facing issue while installing Postgis on my linux machine and the error as below.
"configure: error: the PGXS Makefile /usr/pgsql-12/lib/pgxs/src/makefiles/pgxs.mk cannot be found. Please install the PostgreSQL server development packages and re-run configure."
Command which i am trying to run is --" ./configure --with-pgconfig=/usr/pgsql-12/bin/pg_config".
Please help me over here  I am stuck with my installation.
Regards,
Purushotham
