[postgis-users] ogr_fdw create data source connection error for directory containing XLSX files
karsten karsten at terragis.net
Wed Jul 15 14:51:14 PDT 2020
Thanks for the hint.
Yes that is a route via converting to csv one can go and maybe also script.
I took a stab at creating a simple bash script to iterate over a directory
of xlsx files and creating connection SQL syntax via the
ogr_fdw_info utility, writing that into a temp SQL file and then running
that via psql. Maybe not really pretty but it works - see below.
Maybe I could try to wrap that into a custom psql function ...
Cheers
Karsten
##!/bin/bash
fdwservername="myserver"
exceltabname="raw_data"
databasename="cmein"
tempfile="load_fdw_exceltabs.sql"
# remove file if exists
cmd="rm $tempfile"
echo "removing old file $tempfile"
$cmd
for f in *.xlsx
do
  file=${f##*/}
  fbase=\"${file%%.*}\"
  twoquotes=\"\"
  onequote=\"
  fullexcelfilewithpath="$PWD/$f"
  excel_table_source="datasource '"
  echo "Processing $f file, creating SQL to create foreign table defs via
ogr_fdw_info utility ..."
  #  ogr_fdw_info connand for each file
  ofdwcommand=$(ogr_fdw_info -s $PWD/$f -l "RAW DATA")
  # replace all server and table names and quotes in ogr_fdw_info utility
output
  ofdwcommand=${ofdwcommand//$fdwservername/$fbase}
  ofdwcommand=${ofdwcommand//$exceltabname/$fbase}
  ofdwcommand=${ofdwcommand//$twoquotes/$onequote}
  echo "saving SQL to $tempfile"
  printf "$ofdwcommand" >> "$tempfile"
done
psqlcommand="psql -d $databasename -U postgres -f $tempfile"
echo "running $psqlcommand ..."
$psqlcommand
I don’t think so.  If it  is possible I’d be very interested.
It sees an XLSX as a database and each worksheet is a table.
The hack I’ve used in past (kinda klunky) is to use PostgreSQL built in COPY
FROM to read the list of files and dump it in a table.
So something like this:
CREATE TABLE tmp_docs(file_name text PRIMARY KEY);
COPY tmp_docs FROM PROGRAM 'ls /data/*'  WITH (format 'csv');
And then write a plpgsql procedure that for each record in the table forms
the  create server and foreign table and then drops it when done.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
<https://lists.osgeo.org/mailman/listinfo/postgis-users> ] On Behalf
Of karsten
Sent: Tuesday, July 14, 2020 5:01 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] ogr_fdw create data source connection error for
Hi All,
I am learning how to use the get feature of foreign data wrappers and
successfully connected to various ogr data sources using ogr_fdw on postgres
12 on an ubuntu 16.04 server.
I wanted to use this to import a whole lot of data from XLSX files and was
able to get one table connected as below perfectly all good to go ...
CREATE SERVER cmein_xlsx
  FOREIGN DATA WRAPPER ogr_fdw
  OPTIONS (
        datasource '/var/xy/mapdata/source/geodata/xy1.xlsx',
        format 'XLSX' );
IMPORT FOREIGN SCHEMA ogr_all
    LIMIT TO("Raw Data")
FROM SERVER cmein_xlsx INTO public
OPTIONS(launder_table_names 'false', launder_column_names 'true');
However I read that (at least with shape files) it is possible to
alternatively to connect to a directory (and such to all shape file inside)
by setting the data source to that path. So for my XLSX files I tried as
below:
CREATE SERVER all_cmein_xlsx
  OPTIONS (
        datasource ''/var/xy/mapdata/source/geodata,
        format 'XLSX',
        config_options 'CPL_DEBUG=ON' );
The directory ''/var/xy/mapdata/source/geodata is readable by the postgres
user ...
But the query above gives me the following error :
ERROR: unable to connect to data source "/var/xy/mapdata/source/geodata" SQL
state: HV00N
Is it even possible to connect via ogr_fdw to a directory of multiple XLSX
files like that
and if so what am I missing to make it work ?
Karsten
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200715/2f025214/attachment.html>
