[postgis-users] Problem with union of rasters (postgis 2.4 rds)
Regina Obe
lr at pcorp.us
Tue Jun 2 09:27:47 PDT 2020
ST_AsRaster has a ton of overloaded formats unfortunately. I suspect your
SELECT ST_ASRaster(ST_SetSRID(ST_EXTENT( myQuads), 4326), 0.1, 0.1 ,'8BUI')
Is falling into the overload
raster ST_AsRaster(geometry geom, integer width, integer height, text pixeltype, double precision value=1, double precision nodataval=0, double precision upperleftx=NULL, double precision upperlefty=NULL, double precision skewx=0, double precision skewy=0, boolean touched=false);
Instead of raster ST_AsRaster(geometry geom, double precision scalex, double precision scaley, text pixeltype, double precision value=1, double precision nodataval=0, double precision upperleftx=NULL, double precision upperlefty=NULL, double precision skewx=0, double precision skewy=0, boolean touched=false);
Try explicitly specifying the args
SELECT ST_ASRaster(ST_SetSRID(ST_EXTENT( myQuads), 4326), scalex => 0.1, scaley => 0.1 , pixeltype => '8BUI')
For older versions of PostgreSQL, you might need to replace the => with :=
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Lionel Cayla
Sent: Tuesday, June 2, 2020 9:17 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Problem with union of rasters (postgis 2.4 rds)
I am having an issue, when rasterizing a union of rasters. Each of the geometries from my initial table are quads or polygons, and the following SQL command
(that should work according the documentation right?) gives me a raster 2x2 .
CREATE TABLE raster_test AS
(WITH
rast AS (SELECT ST_ASRaster(ST_SetSRID(ST_EXTENT( myQuads), 4326), 0.1, 0.1 ,'8BUI')
FROM myDB,
WHERE ST_IsValid(myQuads)),
raster_ AS (SELECT ST_Union(ST_ASRaster(ST_SetSRID(ST_Force2D( myQuads), 4326), rast.ST_ASRaster), 'SUM')
FROM myDB, rast
WHERE myQuads IS NOT NULL)
SELECT raster_.ST_Union as rast_chunks
FROM raster_, rast );
The command produces the desired raster if I replace my resolution (0.1, 0.1) by the raster size if it's equal to 150. Over that (200 say) I get an alignment error message.
I tried to cast 0.1 to double precision I still get an issue.
I am wondering if I am doing something wrong here or if there's a known issue.
Thanks,
-Lio
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200602/c69bd428/attachment.html>
