[postgis-users] How to install the latest PostGIS (3.0 or very latest) on CentOS 8.1?
Regina Obe
lr at pcorp.us
Fri Jun 5 09:13:32 PDT 2020
Devrim,
Thanks for the instructions, I added to this page -
https://postgis.net/install/
> so therefore, is there anything in that section that I need to do?
https://people.planetpostgresql.org/devrim/index.php?/archives/102-Installin
g-PostGIS-3.0-and-PostgreSQL-12-on-CentOS-8.html
I ran into a stumbling block on a fresh Centos 8.1
dnf -y config-manager --set-enabled PowerTools
Gave - "No such command: config-manager. Please use /usr/bin/dnf --help"
I had to do this beforehand -- can you add this line to the instructions
after the epel-release install.
yum install dnf-plugins-core
#It installed okay after, but when I go to do a yum update I get this error
yum update
Last metadata expiration check: 0:06:57 ago on Fri Jun 5 15:55:27 2020.
Error:
Problem: cannot install the best update candidate for package
gdal30-libs-3.0.4-3.rhel8.x86_64
- nothing provides libzstd.so.1()(64bit) needed by
gdal30-libs-3.0.4-4.rhel8.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to
use not only best candidate packages)
yum update --nobest
shows
Package Architecture Version
Repository Size
Skipping packages with broken dependencies:
gdal30-libs x86_64
3.0.4-4.rhel8 pgdg-common 7.5
M
Transaction Summary
Skip 1 Package
Nothing to do.
Complete!
#any rate seems to have installed okay, but I assume the above will cause
issues for upgrades
testgis=# CREATE EXTENSION postgis;
CREATE EXTENSION
#testgis=# CREATE EXTENSION postgis_raster;
testgis=# SELECT postgis_full_version();
POSTGIS="3.0.1 ec2a9aa" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3"
PROJ="6.3.2" GDAL="GDAL 3.0.4, released 2020/01/28" LIBXML="2.9.7" LI
BJSON="0.13.1" LIBPROTOBUF="1.3.0" WAGYU="0.4.3 (Internal)" RASTER
(1 row)
Thanks,
Regina
