[postgis-users] Doubt about toTopoGeom tolerance
Alexandre Silva amsilva at infoportugal.impresa.pt
Mon Jun 29 09:53:47 PDT 2020
I have trying using the topology to correct some data with marginal errors and in some particular cases i'd like to use a higher snap tolerance than the defined in the topology.
The topology has a tolerance of 0.01m (using a metric projection) and some lines need an higher tolerance of 0.1m to be fixed. Here's the code i used to create the topology and to fix the particular cases:
SELECT topology.CreateTopology('a_topology', 3763, 0.01, true);
UPDATE lines_table
SET topo = topology.toTopoGeom(geom, 'a_topology', 1, 0.1)
WHERE id = 1263;
Even though the line is closer than 0.1m to another line, it isn't snapped. Am i thinking wrong here? Shouldn't the line be snapped? Which of the tolerances prevails?
If this is the expected behaviour is there a better way to do what i'm trying to do?
Thanks in advance,
Alexandre Silva
[http://newsletter.impresapublishing.pt/i/barra_ip.jpg]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200629/8956c87a/attachment.html>
