[postgis-users] How to apply PostGIS spatial functionality on Feature classes in Enterprise GeoDB for Postgres?
Simon Greener
simon at spatialdbadvisor.com
Mon Jun 29 15:26:18 PDT 2020
John,
Regina points to something that needs resolving before you start.
What is the data type of the SHAPE column?
If it is PostGIS's geometry/geography you can read and process it using pl/pgSql directly.
If it is something like sde.ST_Geometry you need to construct a PostGIS geometry from it using ESRI's ST_AsText method and PostGIS's ST_GeomFromText.
Regards
Simon
Get BlueMail for Android
On 30 Jun 2020, 06:13, at 06:13, Regina Obe <lr at pcorp.us> wrote:
>I think ArcGIS has it’s own ST_Geometry format. Is this in postgis
>geometry or ST_Geometry or some other thing?
>From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>Behalf Of John Zhang
>Sent: Monday, June 29, 2020 4:02 PM
>To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
>Subject: [postgis-users] How to apply PostGIS spatial functionality on
>Dear PostGISers,
>I have a need to perform certain spatial analysis to develop a stored
>function on a Feature Class(FC) using pl/pgSQL. The FCs use a Shape
>field to store spatial data. How can I apply PostGIS functionality on
>these FCs, for example, obtain a list of road segments of a known
>segment? Do I have to turn the FCs into spatial tables? If yes, will
>there be any negative impact on regular ArcGIS functionality?
>Your input will be much appreciated. Thank you!
>Yours sincerely,
>John Zhang
>_______________________________________________
>postgis-users mailing list
>https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200630/18db3dde/attachment.html>
