[postgis-users] Changed intersection test speed after PG 11 -> 12 and PostGIS 2.5 -> 3 upgrade
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 2 13:40:50 PST 2020
So, this gets stranger the more I poke, but not in any helpful way.
I installed 3.0.2dev and 2.5.4dev in my Pg12 instance and ran the same
query using your test file.
https://github.com/tomka/tmp/blob/master/postgres/catmaid-postgis-test.pgsql
pg_restore -O -f- catmaid-postgis-test.pgsql | psql postgis254d
And using this test query:
explain analyze SELECT Count(*) FROM (
SELECT te.id, te.parent_id
FROM
treenode_edge te
WHERE ST_3DDWithin(te.edge,
ST_MakePolygon(ST_MakeLine(ARRAY[
ST_MakePoint(471548.0,
290140.0, 160420.0),
ST_MakePoint(542460.0, 290140.0, 160420.0),
ST_MakePoint(542460.0, 330140.0, 160420.0),
ST_MakePoint(471548.0, 290140.0, 160420.0)]::geometry[])),
20.0)
) a;
And I get a 8ms execution from 12/3 and a 128ms execution from 12/2.5!
--- pg12/postgis3.0
Aggregate (cost=584.97..584.98 rows=1 width=8) (actual
time=7.155..7.155 rows=1 loops=1)
-> Index Scan using treenode_edge_gix on treenode_edge te
(cost=0.53..584.88 rows=33 width=0) (actual time=0.706..7.057 rows=143
loops=1)
Index Cond: (edge &&&
st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry,
'20'::double precision))
Filter: st_3ddwithin(edge,
Planning Time: 2.843 ms
Execution Time: 7.278 ms
-- pg12/postgis2.5
Aggregate (cost=14477.72..14477.73 rows=1 width=8) (actual
time=148.645..148.645 rows=1 loops=1)
-> Bitmap Heap Scan on treenode_edge te (cost=1142.85..14472.35
rows=2151 width=0) (actual time=16.940..148.583 rows=143 loops=1)
Recheck Cond: (edge &&
'0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
Filter:
(('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry
&& st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge,
Rows Removed by Filter: 32400
Heap Blocks: exact=3507
-> Bitmap Index Scan on treenode_edge_2d_gist
(cost=0.00..1142.32 rows=32271 width=0) (actual time=15.024..15.024
rows=32543 loops=1)
Planning Time: 0.833 ms
Execution Time: 148.855 ms
Also, the 12/2.5 query wants to parallelize (???) while the 12/3 one does not.
Anyways, it's super funky and not so helpful.
The trouble with your test set is that it's too small (relative to the
query?) so it's not processing many rows.
If you could run a sampling profiler against your two queries that
would pick up the places where the execution paths differ for the
different versions, it's all I'm trying to do, but I haven't been able
to even replicate the behavious so far, so I am at an impasse at this
moment.
P
On Tue, Feb 4, 2020 at 1:01 PM Tom Kazimiers <tom at voodoo-arts.net> wrote:
> >> Thanks for the report. I've ticketed as a bug -
> >> https://trac.osgeo.org/postgis/ticket/4635
> Thanks for filing the ticket Regina!
> On Tue, Feb 04, 2020 at 11:49:44AM -0800, Paul Ramsey wrote:
> >OK, cleaning this out a little.
> >Ticket for reference https://trac.osgeo.org/postgis/ticket/4635#comment:2
> "Good" to know that you seem to be able to reproduce this slow-down.
> >First, drop all the rest of your testing SQL and just test the contents
> >of the bb_edge CTE. That seems to be sufficient, and it’s the only
> >spatial part.
> Good point, I should have restricted it to that from beginning.
> >Second, for testing 3.0, drop the use of the &&& operator and see what happens with just the ST_DWithin3D function call, which should be throwing an index op in there implicitly.
> > FROM treenode_edge te
> > WHERE ST_3DDWithin(te.edge, ST_MakePolygon(ST_MakeLine(ARRAY[
> > ST_MakePoint(471548.0, 290140.0, 160420.0),
> > ST_MakePoint(471548.0, 330140.0, 160420.0),
> > 20.0)
> >) a;
> >We are definitely seeing different plans in that CTE.
> This is what I get in the test database with 12/3:
> Aggregate (cost=506.38..506.41 rows=1 width=8) (actual time=1.530..1.530 rows=1 loops=1)
> Buffers: shared hit=198
> -> Index Scan using treenode_edge_gix on treenode_edge te (cost=0.53..506.29 rows=33 width=0) (actual time=0.168..1.512 rows=143 loops=1)
> Index Cond: (edge &&& st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
> Filter: ((project_id = 1) AND st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
> Planning Time: 0.654 ms
> Execution Time: 1.583 ms
> Dropping the &&& operator still allows the use of the index it seems and
> is noticeably faster. (In my original query, I used both &&& and
> ST_3DDWithin, because I wanted to reduce the number of false positives
> that I would get with only one of them in some densely populated areas.
> The &&& would make sure every result object bounding box intersects with
> the query bounding box and the ST_3DDWithin would ensure I don't get
> edges that are actually only passing by somewhere close, but not
> actually intersecting the field of view. The line/geometry used with
> ST_3DDWithin is in fact a flat cut through the center of the query
> bounding box. Therefore I believe I still need the &&& in production,
> unfortunately.)
> This is what I get for the above query with the test database in the
> 11/2.5 setup:
> Finalize Aggregate (cost=10302.14..10302.17 rows=1 width=8) (actual time=43.245..43.245 rows=1 loops=1)
> Buffers: shared hit=3768
> -> Gather (cost=10301.91..10302.14 rows=2 width=8) (actual time=43.125..47.544 rows=3 loops=1)
> Workers Planned: 2
> Workers Launched: 2
> -> Partial Aggregate (cost=9301.91..9301.94 rows=1 width=8) (actual time=27.190..27.190 rows=1 loops=3)
> -> Parallel Bitmap Heap Scan on treenode_edge te (cost=693.46..9299.66 rows=899 width=0) (actual time=4.058..27.175 rows=48 loops=3)
> Recheck Cond: (edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
> Filter: ((project_id = 1) AND ('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry && st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
> Rows Removed by Filter: 10800
> Heap Blocks: exact=2171
> -> Bitmap Index Scan on treenode_edge_2d_gist (cost=0.00..692.92 rows=32352 width=0) (actual time=5.430..5.430 rows=32543 loops=1)
> Index Cond: (edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
> Buffers: shared hit=261
> Planning Time: 22.836 ms
> Execution Time: 47.885 ms
> Out of curiosity, what is the plan you are seeing?
> >Testing for 12/3:
> >12/3 is picking an index scan on the spatial index, which is turning out to be slower.
> >You can adjust the COST of the ST_3DDWithin down: default cost is 10000.
> >Where does the plan change as you adjust it down?
> >ALTER FUNCTION ST_3DDWithin COST 9000;
> Once I set it to 608 and lower, this is what I get:
> Aggregate (cost=59.66..59.69 rows=1 width=8) (actual time=1.436..1.436 rows=1 loops=1)
> Buffers: shared hit=183
> -> Bitmap Heap Scan on treenode_edge te (cost=2.18..59.58 rows=33 width=0) (actual time=1.055..1.418 rows=143 loops=1)
> Heap Blocks: exact=119
> -> Bitmap Index Scan on treenode_edge_gix (cost=0.00..2.17 rows=19 width=0) (actual time=1.027..1.027 rows=143 loops=1)
> Buffers: shared hit=64
> Planning Time: 0.703 ms
> Execution Time: 1.516 ms
> The planner doesn't come up with any other plan if I set it to anything
> lower than 608.
> >A big change between 2.5 and 3.0 was costing on spatial functions, so
> >seeing different plans is not surprising, especially since the
> >mechanisms for building the plan have changed so much (SQL wrapper
> >functions vs Pg12 support functions). It’s possible that with the cost
> >of the function set so high, and actually being seen by the planner
> >now, we’re getting an index scan that, in this case, is less efficient
> >than the alternative.
> I see, thanks for the explanation. In my the 12/3 version of my
> production database (50 million edges), I can't reproduce the cost based
> plan change from above though. No matter how low I set the function cost
> there, I always get the spatial scan in the plan.
> Cheers,
> Tom
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
