[postgis-users] st_union
Paul Ramsey pramsey at cleverelephant.ca
Mon Mar 2 14:01:42 PST 2020
On Mon, Mar 2, 2020 at 1:16 PM Alexandre Neto <senhor.neto at gmail.com> wrote:
> Stating the obvious,
> Do you have a spatial index on your geom column?
That will make no difference, the query is reading the whole contents
of the column, a spatial index will do nothing.
P
> Alexandre Neto
> A segunda, 2/03/2020, 17:04, Paul Ramsey <pramsey at cleverelephant.ca> escreveu:
>> No, if it’s returning the answer you want, that’s the way to do it, and there’s no way around it.
>> > On Mar 2, 2020, at 6:25 AM, <paul.malm at lfv.se> <paul.malm at lfv.se> wrote:
>> > Hi list,
>> > I would like to do this:
>> > CREATE TABLE public."Areas_union" AS select  (st_dump(st_union("the_geom"))).geom from "Areas";
>> > But it takes such a long time to execute, is there a smarter way to do it?
>> > Kind regards,
>> > Paul
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
