[postgis-users] st_union
paul.malm at lfv.se paul.malm at lfv.se
Mon Mar 2 22:29:24 PST 2020
Thanks Paul and Alexande!
/Paul
Från: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] För Alexandre Neto
Skickat: den 3 mars 2020 01:53
Till: PostGIS Users Discussion
Ämne: Re: [postgis-users] st_union
Uhmmm... So, if there's no join or where clause, the index is not used at all?
Somehow, I thought that internally ST_union would still use it to decide which geometries need be merged together in the same part.
Thanks for clarifying.
Alexandre Neto
A segunda, 2/03/2020, 22:02, Paul Ramsey <pramsey at cleverelephant.ca<mailto:pramsey at cleverelephant.ca>> escreveu:
On Mon, Mar 2, 2020 at 1:16 PM Alexandre Neto <senhor.neto at gmail.com<mailto:senhor.neto at gmail.com>> wrote:
> Stating the obvious,
> Do you have a spatial index on your geom column?
That will make no difference, the query is reading the whole contents
of the column, a spatial index will do nothing.
P
> Alexandre Neto
> A segunda, 2/03/2020, 17:04, Paul Ramsey <pramsey at cleverelephant.ca<mailto:pramsey at cleverelephant.ca>> escreveu:
>> No, if it’s returning the answer you want, that’s the way to do it, and there’s no way around it.
>> > On Mar 2, 2020, at 6:25 AM, <paul.malm at lfv.se<mailto:paul.malm at lfv.se>> <paul.malm at lfv.se<mailto:paul.malm at lfv.se>> wrote:
>> > Hi list,
>> > I would like to do this:
>> > CREATE TABLE public."Areas_union" AS select  (st_dump(st_union("the_geom"))).geom from "Areas";
>> > But it takes such a long time to execute, is there a smarter way to do it?
>> > Kind regards,
>> > Paul
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>
>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200303/cd6ccf78/attachment.html>
