[postgis-users] Changed intersection test speed after PG 11 -> 12 and PostGIS 2.5 -> 3 upgrade
Tom Kazimiers tom at voodoo-arts.net
Thu Mar 5 05:28:14 PST 2020
A small correction to my last mail: I only noticed after I have sent it
that the 11.7/2.5 query didn't load everything from memory and had to
hit the disk (Buffers: shared hit=302 read=1349 dirtied=2). This is the
first query, with everything in cache:
11.7/2.5.2 (query 1 with &&&):
  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.42..353.59 rows=1 width=16) (actual time=0.656..23.590 rows=1005 loops=1)
    Index Cond: (edge &&& '01020000800200000000000000F0C71C41000000007026144100000000C095034100000000F88D20410000000070B511410000000080940341'::geometry)
    Filter: ((edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry) AND (project_id = 1) AND ('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry && st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
    Rows Removed by Filter: 5
    Buffers: shared hit=1621
  Planning Time: 0.684 ms
  Execution Time: 23.683 ms
And this fits indeed better to the initial observation that PostGIS 2.5
is faster than 3.0 for this query if both &&& and ST_3DDWithin are used.
3.0 is faster if &&& is not used, but only because the 2.5 queries get
much slower.
Best,
Tom
On Thu, Mar 05, 2020 at 12:39:06AM -0500, Tom Kazimiers wrote:
>Hi Paul,
>Thank you for your continued effort to find out what's going on here!
>This is all indeed very strange.
>I just set up a second test database with more entries (50 million)
>using 12.2/2.5.3 and ran the relevant query from the initial post
>(returning ~1000 rows) in this database as well as 12.2/3.0 and
>11/2.5.3:
>  EXPLAIN (ANALYZE, BUFFERS)
>  SELECT te.id, te.parent_id
>  FROM treenode_edge te
>  WHERE te.edge &&& ST_MakeLine(ARRAY[
>      ST_MakePoint(471548.0, 330140.0, 160440.0),
>      ST_MakePoint(542460.0, 290140.0, 160400.0)] ::geometry[])
>  AND ST_3DDWithin(te.edge, ST_MakePolygon(ST_MakeLine(ARRAY[
>      ST_MakePoint(471548.0,  290140.0,    160420.0),
>      ST_MakePoint(542460.0, 290140.0,    160420.0),
>      ST_MakePoint(542460.0, 330140.0, 160420.0),
>      ST_MakePoint(471548.0,  330140.0, 160420.0),
>      ST_MakePoint(471548.0,  290140.0,    160420.0)]::geometry[])),
>      20.0)
>  AND te.project_id = 1;
>11.7/2.5.2:
>  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.42..353.59 rows=1 width=16) (actual time=5.386..172.324 rows=1005 loops=1)
>  Planning Time: 1.324 ms
>  Execution Time: 172.535 ms
>12/2.5.3:
>  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.42..391.68 rows=1 width=16) (actual time=0.936..27.404 rows=1005 loops=1)
>    Buffers: shared hit=1370
>  Planning Time: 0.782 ms
>  Execution Time: 27.518 ms
>12/3.0:
>  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.67..28.71 rows=1 width=16) (actual time=0.730..163.358 rows=1004 loops=1)
>    Index Cond: ((edge &&& '01020000800200000000000000F0C71C41000000007026144100000000C095034100000000F88D20410000000070B511410000000080940341'::geometry) AND (edge &&& st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision)))
>    Filter: ((project_id = 1) AND st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
>    Buffers: shared hit=6546
>  Planning Time: 1.312 ms
>  Execution Time: 163.471 ms
>This is all very strange. Like in the initial mail, I don't see any
>bitmap scans anymore, only the index scan with different runtimes.
>Also, now the 12/2.5.3 query has now the speed of the original
>11/2.5.3 query (?!) from my first post. The estimates are wrong in on
>all version though. All databases have had run ANALYZE right
>beforehand and have a comparible configuration with the relevant part
>of the data in memory.
>Also, changing the function cost of ST_3DDWithin, doesn't have any
>effect anymore. I can't get it to run with the bitmap heap scan again
>(which doesn't seem to play a role with bigger result sets anyway).
>I suppose the main difference is that 12/2.5.3 was just recreatead
>from a backup and is therefore tightly packed on disk (and memory?).
>Could this have such a big influence?
>The timings above suggest to me that neither Postgres 12 nor PostGIS 3
>have a negative influence on performance here. I will run a vaccum and
>reindex on the 12/3.0 setup (which might take a day or so) and see if
>this changes anything.
>In a previous mail you suggested to only look at the ST_3DDWithin
>part, i,e, using this query:
>   WHERE ST_3DDWithin(te.edge, ST_MakePolygon(ST_MakeLine(ARRAY[
>       20.0)
>And this is how that looks like:
>11/2.5.3:
>  Gather  (cost=16804.64..590073.63 rows=30 width=16) (actual time=366.372..1123.021 rows=782 loops=1)
>    Workers Planned: 4
>    Workers Launched: 4
>    Buffers: shared hit=371525
>    ->  Parallel Bitmap Heap Scan on treenode_edge te  (cost=15804.64..589070.63 rows=8 width=16) (actual time=372.224..994.656 rows=156 loops=5)
>          Recheck Cond: (edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
>          Filter: ((project_id = 1) AND ('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry && st_expand(edge, '20'::double precision)) AND _st_3ddwithin(edge, '0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
>          Rows Removed by Filter: 187033
>          Heap Blocks: exact=97218
>          ->  Bitmap Index Scan on treenode_edge_2d_gist  (cost=0.00..15804.63 rows=916441 width=0) (actual time=204.907..204.907 rows=1105737 loops=1)
>                Index Cond: (edge && '0103000080010000000500000000000000A0C71C410000000020B51141000000008094034100000000A0C71C4100000000C0261441000000008094034100000000208E204100000000C026144100000000C095034100000000208E20410000000020B5114100000000C095034100000000A0C71C410000000020B511410000000080940341'::geometry)
>                Buffers: shared hit=9758
>  Planning Time: 0.470 ms
>  JIT:
>    Functions: 30
>    Options: Inlining true, Optimization true, Expressions true, Deforming true
>    Timing: Generation 4.219 ms, Inlining 197.812 ms, Optimization 188.993 ms, Emission 79.596 ms, Total 470.619 ms
>  Execution Time: 1124.520 ms
>12/2.5.3:
>  Gather  (cost=24934.73..862262.11 rows=79121 width=16) (actual time=192.531..770.051 rows=1005 loops=1)
>    Workers Planned: 4
>    Workers Launched: 4
>    Buffers: shared hit=104591
>    ->  Parallel Bitmap Heap Scan on treenode_edge te  (cost=23934.73..853350.01 rows=19780 width=16) (actual time=153.920..675.015 rows=201 loops=5)
>          Rows Removed by Filter: 244695
>          Heap Blocks: exact=23644
>          ->  Bitmap Index Scan on treenode_edge_2d_gist  (cost=0.00..23914.95 rows=1220804 width=0) (actual time=158.067..158.068 rows=1224482 loops=1)
>                Buffers: shared hit=10480
>  Execution Time: 770.358 ms
>12/3.0:
>  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.67..5577.07 rows=4755 width=16) (actual time=0.453..90.967 rows=1004 loops=1)
>    Index Cond: (edge &&& st_expand('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry, '20'::double precision))
>    Rows Removed by Filter: 7
>    Buffers: shared hit=6547 read=4
>  Planning Time: 0.643 ms
>  Execution Time: 91.079 ms
>Interestingly, here, 12/3.0 does better and doesn't attempt to
>parallelize like you observed as well or try to use JIT (it's enabled
>in all clusters). At least with PostGIS 2.5 it seems the extra &&& is
>also helpful for performance (and I might need the &&& to limit the
>results a bit more). Still, while the 12/3 ST_3DDWithin part is faster
>than the whole thing on 12/3 run is faster now than the above 12/2.5.3
>run.
>Without knowing much about the internals of the indices used, I would
>assume that a REINDEX could indeed help, because the index scan would
>then likely need to cover less memory. If this doesn't explain the
>timing difference, I will recreate the 12/3.0 database from scratch
>just like I created the 12/2.5 database today (before I believe the
>12/3.0 was created by `pg_upgrade --link`).
>Best,
>Tom
>On Mon, Mar 02, 2020 at 01:40:50PM -0800, Paul Ramsey wrote:
>>So, this gets stranger the more I poke, but not in any helpful way.
>>I installed 3.0.2dev and 2.5.4dev in my Pg12 instance and ran the same
>>query using your test file.
>>https://github.com/tomka/tmp/blob/master/postgres/catmaid-postgis-test.pgsql
>>pg_restore -O -f- catmaid-postgis-test.pgsql | psql postgis254d
>>And using this test query:
>>explain analyze SELECT Count(*) FROM (
>>                                                             FROM
>>treenode_edge te
>>         20.0)
>>) a;
>>And I get a 8ms execution from 12/3 and a 128ms execution from 12/2.5!
>>--- pg12/postgis3.0
>>Aggregate  (cost=584.97..584.98 rows=1 width=8) (actual
>>time=7.155..7.155 rows=1 loops=1)
>>  ->  Index Scan using treenode_edge_gix on treenode_edge te
>>(cost=0.53..584.88 rows=33 width=0) (actual time=0.706..7.057 rows=143
>>loops=1)
>>        Filter: st_3ddwithin(edge,
>>Planning Time: 2.843 ms
>>Execution Time: 7.278 ms
>>-- pg12/postgis2.5
>>Aggregate  (cost=14477.72..14477.73 rows=1 width=8) (actual
>>time=148.645..148.645 rows=1 loops=1)
>>  ->  Bitmap Heap Scan on treenode_edge te  (cost=1142.85..14472.35
>>rows=2151 width=0) (actual time=16.940..148.583 rows=143 loops=1)
>>        Filter:
>>(('0103000080010000000500000000000000F0C71C410000000070B51141000000002095034100000000F88D20410000000070B51141000000002095034100000000F88D20410000000070261441000000002095034100000000F0C71C410000000070261441000000002095034100000000F0C71C410000000070B511410000000020950341'::geometry
>>        Rows Removed by Filter: 32400
>>        Heap Blocks: exact=3507
>>(cost=0.00..1142.32 rows=32271 width=0) (actual time=15.024..15.024
>>rows=32543 loops=1)
>>Planning Time: 0.833 ms
>>Execution Time: 148.855 ms
>>Also, the 12/2.5 query wants to parallelize (???) while the 12/3 one does not.
>>Anyways, it's super funky and not so helpful.
>>The trouble with your test set is that it's too small (relative to the
>>query?) so it's not processing many rows.
>>If you could run a sampling profiler against your two queries that
>>would pick up the places where the execution paths differ for the
>>different versions, it's all I'm trying to do, but I haven't been able
>>to even replicate the behavious so far, so I am at an impasse at this
>>moment.
>>P
>>On Tue, Feb 4, 2020 at 1:01 PM Tom Kazimiers <tom at voodoo-arts.net> wrote:
>>>>> Thanks for the report.  I've ticketed as a bug -
>>>>> https://trac.osgeo.org/postgis/ticket/4635
>>>Thanks for filing the ticket Regina!
>>>On Tue, Feb 04, 2020 at 11:49:44AM -0800, Paul Ramsey wrote:
>>>>OK, cleaning this out a little.
>>>>Ticket for reference https://trac.osgeo.org/postgis/ticket/4635#comment:2
>>>"Good" to know that you seem to be able to reproduce this slow-down.
>>>>First, drop all the rest of your testing SQL and just test the contents
>>>>of the bb_edge CTE. That seems to be sufficient, and it’s the only
>>>>spatial part.
>>>Good point, I should have restricted it to that from beginning.
>>>>Second, for testing 3.0, drop the use of the &&& operator and see what happens with just the ST_DWithin3D function call, which should be throwing an index op in there implicitly.
>>>>        20.0)
>>>>) a;
>>>>We are definitely seeing different plans in that CTE.
>>>This is what I get in the test database with 12/3:
>>>  Aggregate  (cost=506.38..506.41 rows=1 width=8) (actual time=1.530..1.530 rows=1 loops=1)
>>>    Buffers: shared hit=198
>>>    ->  Index Scan using treenode_edge_gix on treenode_edge te  (cost=0.53..506.29 rows=33 width=0) (actual time=0.168..1.512 rows=143 loops=1)
>>>  Planning Time: 0.654 ms
>>>  Execution Time: 1.583 ms
>>>Dropping the &&& operator still allows the use of the index it seems and
>>>is noticeably faster. (In my original query, I used both &&& and
>>>ST_3DDWithin, because I wanted to reduce the number of false positives
>>>that I would get with only one of them in some densely populated areas.
>>>The &&& would make sure every result object bounding box intersects with
>>>the query bounding box and the ST_3DDWithin would ensure I don't get
>>>edges that are actually only passing by somewhere close, but not
>>>actually intersecting the field of view. The line/geometry used with
>>>ST_3DDWithin is in fact a flat cut through the center of the query
>>>bounding box. Therefore I believe I still need the &&& in production,
>>>unfortunately.)
>>>This is what I get for the above query with the test database in the
>>>11/2.5 setup:
>>>  Finalize Aggregate  (cost=10302.14..10302.17 rows=1 width=8) (actual time=43.245..43.245 rows=1 loops=1)
>>>    Buffers: shared hit=3768
>>>    ->  Gather  (cost=10301.91..10302.14 rows=2 width=8) (actual time=43.125..47.544 rows=3 loops=1)
>>>          Workers Planned: 2
>>>          Workers Launched: 2
>>>          ->  Partial Aggregate  (cost=9301.91..9301.94 rows=1 width=8) (actual time=27.190..27.190 rows=1 loops=3)
>>>                ->  Parallel Bitmap Heap Scan on treenode_edge te  (cost=693.46..9299.66 rows=899 width=0) (actual time=4.058..27.175 rows=48 loops=3)
>>>                      Rows Removed by Filter: 10800
>>>                      Heap Blocks: exact=2171
>>>                      ->  Bitmap Index Scan on treenode_edge_2d_gist  (cost=0.00..692.92 rows=32352 width=0) (actual time=5.430..5.430 rows=32543 loops=1)
>>>                            Buffers: shared hit=261
>>>  Planning Time: 22.836 ms
>>>  Execution Time: 47.885 ms
>>>Out of curiosity, what is the plan you are seeing?
>>>>Testing for 12/3:
>>>>12/3 is picking an index scan on the spatial index, which is turning out to be slower.
>>>>You can adjust the COST of the ST_3DDWithin down: default cost is 10000.
>>>>Where does the plan change as you adjust it down?
>>>>ALTER FUNCTION ST_3DDWithin COST 9000;
>>>Once I set it to 608 and lower, this is what I get:
>>>  Aggregate  (cost=59.66..59.69 rows=1 width=8) (actual time=1.436..1.436 rows=1 loops=1)
>>>    Buffers: shared hit=183
>>>    ->  Bitmap Heap Scan on treenode_edge te  (cost=2.18..59.58 rows=33 width=0) (actual time=1.055..1.418 rows=143 loops=1)
>>>          Heap Blocks: exact=119
>>>          ->  Bitmap Index Scan on treenode_edge_gix  (cost=0.00..2.17 rows=19 width=0) (actual time=1.027..1.027 rows=143 loops=1)
>>>                Buffers: shared hit=64
>>>  Planning Time: 0.703 ms
>>>  Execution Time: 1.516 ms
>>>The planner doesn't come up with any other plan if I set it to anything
>>>lower than 608.
>>>>A big change between 2.5 and 3.0 was costing on spatial functions, so
>>>>seeing different plans is not surprising, especially since the
>>>>mechanisms for building the plan have changed so much (SQL wrapper
>>>>functions vs Pg12 support functions). It’s possible that with the cost
>>>>of the function set so high, and actually being seen by the planner
>>>>now, we’re getting an index scan that, in this case, is less efficient
>>>>than the alternative.
>>>I see, thanks for the explanation. In my the 12/3 version of my
>>>production database (50 million edges), I can't reproduce the cost based
>>>plan change from above though. No matter how low I set the function cost
>>>there, I always get the spatial scan in the plan.
>>>Cheers,
>>>Tom
>>>_______________________________________________
>>>postgis-users mailing list
>>>postgis-users at lists.osgeo.org
>>>https://lists.osgeo.org/mailman/listinfo/postgis-users
