[postgis-users] JOIN performance for ST_Point()
Ryo NEYAMA neyama at toyota-tokyo.tech
Thu Mar 5 15:51:06 PST 2020
Hello,
Thank you for the information.
I'll try it with PostGIS 3.0.
Ryo
2020年3月5日(木) 19:01 Darafei "Komяpa" Praliaskouski <me at komzpa.net>:
> Hello,
> Equality has been significantly reworked in 3.0. Can you reproduce
> your issue in PostGIS 3.0?
> On Thu, Mar 5, 2020 at 9:46 AM Ryo NEYAMA <neyama at toyota-tokyo.tech>
> wrote:
> > Hello,
> > I had a performance issue when I JOIN two tables by using the equivalence
> > of two ST_Point()s.
> > I'm wondering if it is a kind of specification...
> > -- SQL statements FROM HERE
> > BEGIN;
> > SELECT version(), postgis_version();
> > DROP TABLE IF EXISTS table1;
> > DROP TABLE IF EXISTS table2;
> > CREATE TEMPORARY SEQUENCE gen_serial;
> > CREATE TABLE table1 AS (
> >   SELECT
> >     nextval('gen_serial') AS id,
> >     ST_Point(x, y) AS coord
> >   FROM (
> >     SELECT
> >       x, y
> >     FROM
> >       (SELECT generate_series(1, 100) x) set_x
> >     CROSS JOIN
> >       (SELECT generate_series(1, 100) y) set_y
> >   ) tmp
> > CREATE TABLE table2 AS (
> >   SELECT
> >   FROM (
> >     SELECT
> >       x, y
> >     FROM
> >       (SELECT generate_series(25, 75) x) set_x
> >     CROSS JOIN
> >       (SELECT generate_series(25, 75) y) set_y
> >   ) tmp
> > -- test case (1)
> > EXPLAIN ANALYZE
> > SELECT
> >   COUNT(*)
> > FROM
> >   table1
> > JOIN
> >   table2
> > ON
> >   ST_Equals(table1.coord, table2.coord)
> > -- test case (2)
> > EXPLAIN ANALYZE
> > SELECT
> >   COUNT(*)
> > FROM
> >   table1
> > JOIN
> >   table2
> > ON
> >   table1.coord = table2.coord
> > -- test case (3)
> > EXPLAIN ANALYZE
> > SELECT
> >   COUNT(*)
> > FROM
> >   table1
> > JOIN
> >   table2
> > ON
> >   ST_AsText(table1.coord) = ST_AsText(table2.coord)
> > END;
> > -- SQL statements TO HERE
> > -- Results FROM HERE
> > BEGIN
> >                                                              version
> >  postgis_version
> >  PostgreSQL 11.2 (Debian 11.2-1.pgdg90+1) on x86_64-pc-linux-gnu,
> compiled
> > by gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516, 64-bit | 2.5 USE_GEOS=1
> > USE_PROJ=1 USE_STATS=1
> > (1 row)
> > DROP TABLE
> > DROP TABLE
> > CREATE SEQUENCE
> > SELECT 10000
> > SELECT 2601
> >                                                         QUERY PLAN
> >  Aggregate  (cost=7052229.97..7052229.98 rows=1 width=8) (actual
> > time=7096.372..7096.373 rows=1 loops=1)
> >    ->  Nested Loop  (cost=0.00..7052207.80 rows=8870 width=0) (actual
> > time=1692.069..7096.193 rows=2601 loops=1)
> >          Join Filter: ((table1.coord ~= table2.coord) AND
> > _st_equals(table1.coord, table2.coord))
> >          Rows Removed by Join Filter: 26007399
> >          ->  Seq Scan on table1  (cost=0.00..184.80 rows=10080 width=32)
> > (actual time=0.004..0.767 rows=10000 loops=1)
> >          ->  Materialize  (cost=0.00..61.60 rows=2640 width=32) (actual
> > time=0.000..0.090 rows=2601 loops=10000)
> >                ->  Seq Scan on table2  (cost=0.00..48.40 rows=2640
> > width=32) (actual time=0.004..0.244 rows=2601 loops=1)
> >  Planning Time: 0.136 ms
> >  Execution Time: 7096.493 ms
> > (9 rows)
> >                                                         QUERY PLAN
> >  Aggregate  (cost=399474.33..399474.34 rows=1 width=8) (actual
> > time=6870.980..6870.980 rows=1 loops=1)
> >    ->  Nested Loop  (cost=0.00..399407.80 rows=26611 width=0) (actual
> > time=1665.642..6870.790 rows=2601 loops=1)
> >          Join Filter: (table1.coord = table2.coord)
> > (actual time=0.004..0.870 rows=10000 loops=1)
> > time=0.000..0.099 rows=2601 loops=10000)
> > width=32) (actual time=0.004..0.258 rows=2601 loops=1)
> >  Planning Time: 0.031 ms
> >  Execution Time: 6871.063 ms
> > (9 rows)
> >                                                           QUERY PLAN
> >  Aggregate  (cost=512255.20..512255.21 rows=1 width=8) (actual
> > time=44.998..44.998 rows=1 loops=1)
> >    ->  Merge Join  (cost=1053.52..511922.56 rows=133056 width=0) (actual
> > time=42.285..44.865 rows=2601 loops=1)
> >          Merge Cond: ((st_astext(table2.coord)) =
> (st_astext(table1.coord)))
> >          ->  Sort  (cost=198.44..205.04 rows=2640 width=32) (actual
> > time=4.408..4.514 rows=2601 loops=1)
> >                Sort Key: (st_astext(table2.coord))
> >                Sort Method: quicksort  Memory: 300kB
> > width=32) (actual time=0.018..3.587 rows=2601 loops=1)
> >          ->  Sort  (cost=855.08..880.28 rows=10080 width=32) (actual
> > time=37.466..37.760 rows=7329 loops=1)
> >                Sort Key: (st_astext(table1.coord))
> >                Sort Method: quicksort  Memory: 1166kB
> > width=32) (actual time=0.005..13.276 rows=10000 loops=1)
> >  Planning Time: 0.088 ms
> >  Execution Time: 45.104 ms
> > (13 rows)
> > COMMIT
> > -- Results TO HERE
> > The above three SQL statements, test case (1), (2), and (3) provides
> > exactly the same result, i.e. count = 2601.
> > The test case (1) uses ST_Equals and (2) uses '=' for comparison.
> > The test case (3) converts a ST_Point to text by using ST_AsText().
> > The test case (1)(2) is more intuitive and straightforward than the test
> > case (3).
> > However, the test case (3) is much faster than the test cases (1) and
> (2).
> > As described in QUERY PLAN, only the test case (3) could benefit from
> > Sort-Merge-Join.
> > Is it possible to get the equivalent performance with test case (1) and
> (2)?
> > Best regards,
> > Ryo Neyama
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/postgis-users
> Darafei Praliaskouski
> Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200306/fa85f6fa/attachment.html>
