[postgis-users] ogr_fdw installation error
rmrodriguez at carto.com rmrodriguez at carto.com
Fri Mar 6 05:18:06 PST 2020
It looks like you might be loading multiple versions of the same
library (likely GEOS) at the same time. Please make sure that both
Postgis and ogr_fdw are built against the exact same dependencies if
you are going to use both in a single SQL session.
On Fri, Mar 6, 2020 at 2:03 PM Zwettler Markus (OIZ)
<Markus.Zwettler at zuerich.ch> wrote:
> Curios:
> 1. select PostGIS_Full_Version();
> 2. drop extension if exists ogr_fdw;
> 3. create extension ogr_fdw;               => everything fine
> 1. drop extension if exists ogr_fdw;
> 2. create extension ogr_fdw;             => ERROR:  could not load...
> 3. select PostGIS_Full_Version();        => server closed the connection unexpectedly...
> Details below.
> Any idea on this one?
> -Markus
> $ psql
> monitor at pcl_l202:pdb_l22_oiz # drop extension if exists ogr_fdw;
> NOTICE:  extension "ogr_fdw" does not exist, skipping
> Time: 0.551 ms
> monitor at pcl_l202:pdb_l22_oiz # create extension ogr_fdw;
> ERROR:  could not load library "/usr/pgsql-12/lib/ogr_fdw.so": /usr/gdal30/lib/libgdal.so.26: undefined symbol: GEOSMakeValid_r
> Time: 73.423 ms
> monitor at pcl_l202:pdb_l22_oiz # select PostGIS_Full_Version();
>         This probably means the server terminated abnormally
>         before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> Time: 1024.585 ms (00:01.025)
> @pcl_l202: > \q
> $ psql
>        postgis_full_version
> POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 " PROJ="Rel. 6.2.1, November 1st, 2019" GDAL="GDAL 3.0.4, released 2020/01/28" LIBXML="2.9.1" LIBJSON="0.11" LIBPROTOBUF="1.0.2" TOPOLOGY RASTER
> (1 row)
> Time: 159.242 ms
> Time: 0.433 ms
> Time: 6.024 ms
> monitor at pcl_l202:pdb_l22_oiz # select * from version();
>                                                  version
> PostgreSQL 12.2 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39), 64-bit
> (1 row)
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Raúl Marín Rodríguez
carto.com
