[postgis-users] Help with SQL
Martin Davis mtnclimb at gmail.com
Mon Mar 9 10:39:07 PDT 2020
A slight correction to the SQL (JOINs need an ON condition, which in this
case is simply TRUE)
SELECT poly.id, obs_max.*
FROM polyobstacle poly
JOIN LATERAL (SELECT * FROM obstacles o
  WHERE ST_Contains(poly.geom, o.geom)
 ORDER BY height_m LIMIT 1
  ) AS obs_max ON true;
On Mon, Mar 9, 2020 at 9:28 AM Martin Davis <mtnclimb at gmail.com> wrote:
> This is a good case for using a LATERAL JOIN:
>   ) obs_max
> On Mon, Mar 9, 2020 at 2:21 AM <paul.malm at lfv.se> wrote:
>> Hi,
>> I have 2 tables:
>> obstacles (point layer) with a column height_m (INTEGER) and a
>> polyobstacles (polygon layer)
>> the point layer has obstacles all over the map and the polygon layer has
>> some polygons containing some of the obstacle points.
>> Now I would like to select the highest obstacle in each polygon. If there
>> is several points with the same highest height a random obstacle of those
>> highest shall be selected.
>> Is there someone that can get me on the track for such a query, I’m
>> losing myself in subqueries?
>> Kind regards,
>> Paul
>>     [image: 2_LFV_engelsk_96]
>> *   Paul Malm*
>>    Operations AIM
>>    Direct  +46 (0)8 797 70 23  Mobile: +46 (0)708 601115
>>    paul.malm at lfv.se
>>    Mail & Visit: Löjtnantsgatan 25, 115 50 Stockholm, Sweden
>>    Unit phone: +46 (0)8 797 70 20
>>    www.lfv.se
>>    Please consider the enviroment before printing this e-mail message.
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200309/c1b174ad/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200309/c1b174ad/attachment.jpg>
