[postgis-users] PostGIS functions not working on AWS via Lambda function
Alexander Gataric
gataric at usa.net
Tue Mar 17 14:22:46 PDT 2020
Thanks, that did it! The extension was public and I modified the set path statement to include it.
Get BlueMail for Android
On Mar 17, 2020, 2:55 PM, at 2:55 PM, Giuseppe Broccolo <g.broccolo.7 at gmail.com> wrote:
>Ok, check in which schema PostGIS operators/functions have been
>defined,
>then
>use fully qualified names of the functions in your UDF.
>Giuseppe.
>Il giorno mar 17 mar 2020 alle ore 18:16 Alexander Gataric
><gataric at usa.net>
>ha scritto:
>> It says the extension already exists.
>> Get BlueMail for Android <http://www.bluemail.me/r?b=15824>
>> On Mar 17, 2020, at 12:07 PM, Giuseppe Broccolo
>> wrote:
>>> Ok, as I told befire lambda functions should rely on RDS instances.
>Once
>>> you open a connection
>>> to the DB through psycopg, enable the Postgis extension with
>>> cur.execute("CREATE EXTENSION postgis")
>>> then try to run your UDF.
>>> Giuseppe.
>>> Il giorno mar 17 mar 2020 alle ore 14:38 Alexander Gataric <
>>> gataric at usa.net> ha scritto:
>>>> I get the same error message as if PostGIS isn't installed.
>Function not
>>>> found error.
>>>> I'm invoking in lambda via python code like this:
>>>> import boto3
>>>> import psycopg3
>>>> def lambda_handler(event,lambda_context)
>>>> # login and connection stuff
>>>> cur.execute("select * from schema.udf_name (parm1,parm2)")
>>>> The UDF invokes several PostGIS functions such as st_dwithin.
>>>> On Mar 17, 2020, at 9:04 AM, Giuseppe Broccolo <
>>>> wrote:
>>>>> Hi Alexander,
>>>>> can you add further details (snippet of code, etc.) about this?
>>>>> Never tried doing this, but AFAIK AWS lambda runs on preconfigured
>RDS
>>>>> environments,
>>>>> maybe it's just enough to include the CREATE EXTENSION.
>>>>> Giuseppe.
>>>>> Il giorno mar 17 mar 2020 alle ore 12:55 Alexander Gataric <
>>>>>> I'm trying to create a service to invoke Postgres UDFs that
>utilize
>>>>>> PostGIS
>>>>>> functions via an AWS lambda function. The error I get is as if
>the
>>>>>> PostGIS
>>>>>> extension is not installed. Has anyone encountered this before?
>>>>>> Thanks
>>>>>> Alex
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> postgis-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200317/dc230da2/attachment.html>
