[postgis-users] postgis-users Digest, Vol 217, Issue 15
john polo
jpolo at mail.usf.edu
Wed Mar 25 06:22:35 PDT 2020
I see my mistake. I shouldn't have added the table name between the
first FROM and the second SELECT.
I don't know what's wrong with that row. It looks normal. I suppose the
problem is as others have pointed out: exporting the table to shapefile
leads to a shapefile that exceeds a size limit of which I was not aware.
Merci beaucoup, Freddy.
best regards,
John
On 3/24/2020 9:42 PM, john polo wrote:
> Thanks for the code, Freddy. It doesn't work for me though. I'm still
> pretty new to SQL and subqueries are something I'm still learning, so
> I don't know if there is something obvious I missed in running this.
> I've not seen row_number() before. I read a couple of things online
> and there was something that said the query needs ORDER BY inside the
> OVER() function. However, I don't know what to refer to for an ORDER
> BY(), because I don't know how the table determines the line numbers.
> SELECT *
> FROM p_loc.ebird_sel_spt
> (SELECT *,
> row_number() OVER () AS NumLigne
> ) AS p_loc.ebird_sel_sptAvecNumLigne
> WHERE NumLigne = 3329432;
> ERROR: syntax error at or near "SELECT"
> LINE 3: (SELECT *,
> SQL state: 42601
> Character: 3
> I tried the query without the "AS p_loc.ebird_sel_sptAvecNumLigne". I
> also forgot to change the TaTable that was in the 2nd FROM to
> p_loc.ebird_sel_spt at first. A few other little tweaks didn't seem to
> make it work for me.
> best,
> John
> On 3/23/2020 9:56 AM, Freddy Gonthier wrote:
>> SELECT *
>> FROM
>> (SELECT *,
>> FROM TaTable
>> ) AS TaTableAvecNumLigne
>> Le sam. 21 mars 2020 à 20:01, <postgis-users-request at lists.osgeo.org
>> <mailto:postgis-users-request at lists.osgeo.org>> a écrit :
>> Send postgis-users mailing list submissions to
>> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> postgis-users-owner at lists.osgeo.org
>> <mailto:postgis-users-owner at lists.osgeo.org>
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of postgis-users digest..."
>> Today's Topics:
>> 1. query a certain row from a table. (john polo)
>> 2. Re: query a certain row from a table. (Alexander Gataric)
>> 3. Re: query a certain row from a table. (John Polo)
>> Message: 1
>> Date: Fri, 20 Mar 2020 21:35:21 -0700
>> From: john polo <jpolo at mail.usf.edu <mailto:jpolo at mail.usf.edu>>
>> To: PostGIS Users Discussion <postgis-users at lists.osgeo.org
>> <mailto:postgis-users at lists.osgeo.org>>
>> Subject: [postgis-users] query a certain row from a table.
>> Message-ID: <d05371ca-fcf0-d3e7-c85f-42f144a9132a at mail.usf.edu
>> <mailto:d05371ca-fcf0-d3e7-c85f-42f144a9132a at mail.usf.edu>>
>> Content-Type: text/plain; charset=utf-8; format=flowed
>> Hi,
>> I'm trying to export a table of points to a shapefile. The table has
>> over 8,000,000 rows. I'm using PostGIS 3.0 and PostGIS Shapefile
>> Import/Export Manager on Windows 10. When I try to run the export, I
>> keep getting this error:
>> Error: record 3329432 could not be created
>> I'm not sure how to handle this. My first impulse is find the
>> offending
>> row, but I don't know the SQL for such a query. Is there something I
>> need to write in a WHERE clause or a different clause to get a
>> specific row?
>> Enlightenment is ego's ultimate disappointment.
>> -Chogyam Trungpa
>> Message: 2
>> Date: Sat, 21 Mar 2020 02:36:24 -0500
>> From: Alexander Gataric <gataric at usa.net <mailto:gataric at usa.net>>
>> Subject: Re: [postgis-users] query a certain row from a table.
>> Message-ID: <5c4820aa-f60d-4b7e-9ca1-45da6a8d416a at usa.net
>> <mailto:5c4820aa-f60d-4b7e-9ca1-45da6a8d416a at usa.net>>
>> Content-Type: text/plain; charset="utf-8"
>> What format are the points stored in? Point, multipoint? How many
>> points per row?
>> Get BlueMail for Android
>> On Mar 20, 2020, 11:36 PM, at 11:36 PM, john polo
>> <jpolo at mail.usf.edu <mailto:jpolo at mail.usf.edu>> wrote:
>> >Hi,
>> has
>> export, I
>> offending
>> something I
>> specific
>> >row?
>> >-Chogyam Trungpa
>> >_______________________________________________
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200321/b1b44f20/attachment-0001.html>
>> Message: 3
>> Date: Sat, 21 Mar 2020 08:06:34 -0700
>> From: John Polo <jpolo at mail.usf.edu <mailto:jpolo at mail.usf.edu>>
>> Message-ID:
>> <CALTSVX9DsHew5rm2kbxjTQjDYo11Y9b_xHpy8D7Pm+pSsCB-ww at mail.gmail.com
>> <mailto:CALTSVX9DsHew5rm2kbxjTQjDYo11Y9b_xHpy8D7Pm%2BpSsCB-ww at mail.gmail.com>>
>> They are stored as Point. One per row.
>> On Saturday, March 21, 2020, Alexander Gataric <gataric at usa.net
>> many points
>> > per row?
>> > Get BlueMail for Android <http://www.bluemail.me/r?b=15824>
>> > On Mar 20, 2020, at 11:36 PM, john polo <jpolo at mail.usf.edu
>> >> Hi,
>> table has
>> export, I
>> offending
>> something I
>> specific row?
>> URL:
>> <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200321/3c2986ce/attachment-0001.html>
>> Subject: Digest Footer
>> End of postgis-users Digest, Vol 217, Issue 15
> -Chogyam Trungpa
-Chogyam Trungpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200325/ecfd1837/attachment.html>
