[postgis-users] Overlap analysis / polygonize precision problem
Alexandre Neto senhor.neto at gmail.com
Fri Mar 27 09:26:27 PDT 2020
Interesting... Converting the geometries to EPSG:3758 gives me full
precision results... even too much precision in fact.
Am I hitting a possible bug?
create materialized view boundaries6 as
SELECT ST_Union(st_transform(geom,3857)) AS geom
FROM isolated_polygons
create materialized view poligonos as
SELECT (st_dump(st_polygonize(geom))).geom as geom
FROM boundaries6
Output example:
POLYGON ((-1884304.8181563204 3847387.217700834, -1884303.6301477952
3847390.2815198163, -1884301.3926260301 3847398.3850115254,
-1884299.3588698322 3847410.0745247495, -1884297.6065138557
3847432.9725758657, -1884296.370352658 3847461.3124003927,
-1884285.5676204616 3847490.5777932494, -1884284.7220942706
3847500.8949590772, -1884285.5877451708 3847511.209780088,
-1884288.1313066888 3847521.1258629817, -1884292.255031176
3847530.2621367835, -1884304.5612327529 3847544.838597601,
-1884320.6135112965 3847552.7077727388, -1884329.301438646
3847553.711864505, -1884356.7018600577 3847595.5444918745,
-1884350.6091230644 3847597.7214655625, -1884348.8417112504
3847597.9233964435, -1884341.920268925 3847598.7141872644,
-1884341.5547124646 3847598.6704397635, -1884162.206055107
3847732.7449807688, -1884157.330000988 3847741.342988697,
-1884210.2855140327 3848065.4651809186, -1884211.0698977145
3848066.2197755766, -1884217.0682683294 3848071.990343949,
-1884222.6487752784 3848079.961606272, -1884226.8892119355
3848089.3659096505, -1884230.1943484417 3848110.7830938566,
-1884227.0298437525 3848129.5450243745, -1884222.9641946238
3848138.7184024854, -1884217.469721009 3848146.773560765,
-1884209.495630356 3848157.0619211486, -1884202.4868359105
3848163.241048862, -1884194.5976475216 3848167.677591741,
-1884186.1312422808 3848170.201053893, -1884177.412979387
3848170.714458845, -1884157.7120793909 3848163.686625789,
-1884146.5982598332 3848153.4266241263, -1884099.6259874147
3848131.588206478, -1884085.2123215708 3848132.893416493,
-1884074.8880534563 3848129.9745710627, -1884006.686567626
3848152.1387122166, -1883999.7713783819 3848162.432206334,
-1883986.525370213 3848172.981480761, -1883968.1933179696
3848177.6538106035, -1883959.5126945307 3848176.5642115613,
-1883940.3595967775 3848165.418067268, -1883925.5155310663
3848151.8882741183, -1883917.5729368732 3848139.8137890203,
-1883857.381093363 3848111.5022320007, -1883836.6232274584
3848117.720000616, -1883815.6242172741 3848124.2012419687,
-1883795.1043865664 3848130.8164017973, -1883773.7927185367
3848133.674364157, -1883773.4405336839 3848133.6625647387,
-1883764.9307116808 3848131.354253732, -1883756.9635983726
3848127.118674705, -1883749.845365454 3848121.1186005473,
-1883743.8495626273 3848113.5846132124, -1883739.2066052258
3848104.8062422355, -1883736.094919506 3848095.120837853,
-1883734.6340857996 3848084.9006064767, -1883734.8802431289
3848074.538306728, -1883736.823931808 3848064.4321558326,
-1883740.3904569661 3848054.9705263535, -1883751.7045506823
3848030.4666622537, -1883759.5307865026 3848009.899583877,
-1883774.9301102725 3847990.7332227444, -1883788.9531276273
3847983.8276264044, -1883798.370475629 3847982.581636236,
-1883803.3564696491 3847982.6305539324, -1883808.8254005057
3847983.9783169357, -1883811.9033591086 3847984.736848943,
-1883944.2994730875 3847833.871629596, -1883942.3214133624
3847812.6865095636, -1883939.7310583459 3847788.9131205995,
-1883937.3284565676 3847767.9910749495, -1883935.3974736354
3847750.7967956406, -1883936.2118704196 3847732.3826482696,
-1883941.080774071 3847708.957261322, -1883948.428618156
3847684.8137834826, -1883956.7098723128 3847659.216029763,
-1883962.7544886847 3847645.0159646464, -1883976.3805608859
3847622.0625812984, -1883976.4801818964 3847621.894767933,
-1883982.9920693361 3847613.159092793, -1884002.4959315164
3847598.585505623, -1884021.9036816845 3847588.5777258603,
-1884042.4003578553 3847579.661401065, -1884062.794237262
3847570.8390545677, -1884085.218038963 3847559.5058541186,
-1884105.6873629335 3847548.8405457577, -1884146.3744489253
3847487.370838038, -1884148.8150594376 3847470.16256415,
-1884155.6282139579 3847450.87717117, -1884165.1022426507
3847427.336416116, -1884175.1243341307 3847404.260394368,
-1884181.7489672431 3847395.018372707, -1884181.9541160655
3847394.7979852944, -1884188.7488454045 3847388.825408952,
-1884209.00655479 3847374.3355192025, -1884210.7233128822
3847373.107561073, -1884217.8542574504 3847368.986041094,
-1884225.4877985476 3847366.4321310967, -1884246.3156752721
3847361.7921338347, -1884257.154692483 3847360.9777463954,
-1884267.8373182372 3847363.3036133484, -1884281.340372469
3847368.32697293, -1884290.0586065683 3847372.833651344,
-1884304.8181563204 3847387.217700834))
POLYGON ((-1876206.2855346825 3847836.356218301, -1876213.9517881759
3847837.111815559, -1876238.76490267 3847842.148596314, -1876246.4897721622
3847844.580692201, -1876270.5000708427 3847854.957112778,
-1876294.5103695232 3847865.333542457, -1876318.5288631248
3847875.683740962, -1876342.5606370806 3847885.9898018865,
-1876358.1067283235 3847892.6567703243, -1876377.0049311635
3847908.617574078, -1876384.191861699 3847922.941528678,
-1876435.9263317827 3847958.821861747, -1876451.2924678891
3847957.834976292, -1876476.0020765157 3847961.8433128675,
-1876500.7116851422 3847965.8516508057, -1876525.4212937716
3847969.859990095, -1876541.8531569052 3847973.5510454606,
-1876549.7864771339 3847977.875103052, -1876556.8570223656
3847983.9541076478, -1876562.793075515 3847991.554449007,
-1876567.3665173864 3848000.384052895, -1876570.4015931743
3848010.1036049207, -1876571.781666619 3848020.3395898687,
-1876571.4537022691 3848030.6986454, -1876569.4303036134 3848040.782678613,
-1876556.7620823071 3848062.906127123, -1876544.474504419
3848103.1186408913, -1876536.4705924124 3848088.8048734763,
-1876526.8713291166 3848071.158459993, -1876513.8057426987
3848053.8755431217, -1876498.5251660557 3848038.6726656007,
-1876479.0519202838 3848020.8695257055, -1876462.1476702257
3847995.346476615, -1876445.3014369362 3847977.2476997958,
-1876437.1638362387 3847973.497051448, -1876428.566456088
3847971.703829692, -1876419.8396889826 3847971.9369461425,
-1876411.3188996902 3847974.187442382, -1876398.8038840995
3847979.4380840464, -1876390.8282430447 3847983.6509141587,
-1876383.697917834 3847989.6306343884, -1876377.686922866
3847997.1474499176, -1876373.026257304 3848005.91249636,
-1876371.0260549276 3848012.0937245083, -1876368.6388035628
3848036.167851205, -1876372.618960253 3848051.7714296845,
-1876375.7576613792 3848058.5229933336, -1876379.533245313
3848166.297470614, -1876369.775387625 3848183.5411413587,
-1876357.0092722771 3848208.9273151984, -1876344.243156932
3848234.3135435423, -1876336.4445368669 3848251.803340319, -1876310.3890798
3848308.105480734, -1876292.8235339515 3848325.64827115,
-1876275.2579881032 3848343.1910875947, -1876258.140322357
3848360.5178122423, -1876240.6753970124 3848378.435703825,
-1876223.2104716708 3848396.353622561, -1876205.7455463263
3848414.271568451, -1876190.496380243 3848435.2357344097,
-1876188.5041804744 3848441.382478181, -1876175.6802522782
3848446.7096233866, -1876153.964067868 3848454.2477547023,
-1876145.262931562 3848453.4204791524, -1876124.7839309415
3848441.8290587896, -1876116.0862495338 3848430.4926588554,
-1876073.6693214423 3848390.7739995327, -1876063.3791579525
3848387.2665754347, -1875996.553527071 3848384.2336162594,
-1875987.4865948088 3848388.538587899, -1875966.1524373947
3848391.6581394975, -1875947.799369681 3848391.1893235887,
-1875931.4822491563 3848383.680621366, -1875886.9208690752
3848396.831050444, -1875866.7302966597 3848401.7902388633,
-1875849.3606788714 3848402.2474827934, -1875840.953470879
3848399.458762576, -1875822.184677481 3848382.688905822,
-1875815.1690762078 3848367.2838811954, -1875769.1787144816
3848351.7157003637, -1875747.1809534468 3848350.936353597,
-1875743.3813192244 3848349.7308892296, -1875735.5496224375
3848345.1528666974, -1875728.6204446587 3848338.8482701606,
-1875722.8600703056 3848331.0593842687, -1875718.4898673305
3848322.085534141, -1875715.677780184 3848312.2715820787,
-1875714.5318757985 3848301.9946743585, -1875719.8684248503
3848275.5555036473, -1875727.7916337482 3848262.76994325,
-1875750.3362411975 3848222.2697083377, -1875754.7871294252
3848206.5161465644, -1875742.2692607127 3848103.4182770974,
-1875735.1057798397 3848095.3251489033, -1875726.8881497092
3848078.742704152, -1875724.3570128784 3848058.398189097,
-1875718.1938969397 3848009.3275126973, -1875706.8020045527
3847994.471745596, -1875700.7199507852 3847974.7066694116,
-1875700.2843567806 3847964.3532587904, -1875701.5579493775
3847954.097874521, -1875704.4917851256 3847944.334624517,
-1875708.9731183609 3847935.438703329, -1875714.8297339657
3847927.7519739107, -1875721.8365654838 3847921.569830351,
-1875729.7243443066 3847917.1298464444, -1875738.1899475218
3847914.602646254, -1875760.8253876907 3847917.836251649,
-1875779.1813012215 3847927.722407194, -1875839.6392382558
3847916.7080737525, -1875847.6645522898 3847902.902541498,
-1875864.2551363274 3847889.4786811387, -1875872.677495195
3847886.784032957, -1875896.780289324 3847889.2852114723,
-1875920.1179041544 3847895.707716113, -1875937.8505189705
3847903.4325572257, -1875957.5891486697 3847914.1431340575,
-1875977.3277783687 3847924.8537205877, -1876054.1260391686
3847919.4538371777, -1876073.8054144348 3847904.839822452,
-1876093.4847897037 3847890.2258257843, -1876116.2257573933
3847870.791218101, -1876130.4613346022 3847861.037598793,
-1876154.8176802786 3847855.307186942, -1876178.2325191353
3847845.168524966, -1876198.624175414 3847837.178850613,
-1876206.2855346825 3847836.356218301))
POLYGON ((-1876544.474504419 3848103.1186408913, -1876543.8326752747
3848105.2191006835, -1876546.7289264835 3848127.920085206,
-1876545.5359284605 3848137.233395549, -1876542.564784783
3848146.9808798665, -1876538.0494765278 3848155.8526974116,
-1876532.1635244589 3848163.5079068835, -1876511.5703764597
3848175.706514713, -1876497.9576754894 3848176.626671925,
-1876448.8350632659 3848194.056099103, -1876425.3492611286
3848236.5173345227, -1876419.7925063348 3848255.6842517625,
-1876408.3034239912 3848271.162037587, -1876392.7014745248
3848280.240130746, -1876355.8397513435 3848325.7032860224,
-1876352.1625399927 3848341.9048215672, -1876338.9274128082
3848362.1980404467, -1876322.3367223463 3848371.7842661925,
-1876295.3121583033 3848406.0858179284, -1876286.3166743552
3848428.9527952927, -1876279.2407616368 3848437.3597535645,
-1876271.8631297487 3848442.900441352, -1876263.7170912437
3848446.625315366, -1876255.1156938097 3848448.391229029,
-1876232.2128869023 3848442.867444207, -1876213.8676121181
3848430.846339705, -1876188.5041804744 3848441.382478181,
-1876190.496380243 3848435.2357344097, -1876205.7455463263
3848414.271568451, -1876223.2104716708 3848396.353622561,
-1876240.6753970124 3848378.435703825, -1876258.140322357
3848360.5178122423, -1876275.2579881032 3848343.1910875947,
-1876292.8235339515 3848325.64827115, -1876310.3890798 3848308.105480734,
-1876336.4445368669 3848251.803340319, -1876344.243156932
3848234.3135435423, -1876357.0092722771 3848208.9273151984,
-1876369.775387625 3848183.5411413587, -1876379.533245313
3848166.297470614, -1876375.7576613792 3848058.5229933336,
-1876372.618960253 3848051.7714296845, -1876368.6388035628
3848036.167851205, -1876371.0260549276 3848012.0937245083,
-1876373.026257304 3848005.91249636, -1876377.686922866 3847997.1474499176,
-1876383.697917834 3847989.6306343884, -1876390.8282430447
3847983.6509141587, -1876398.8038840995 3847979.4380840464,
-1876411.3188996902 3847974.187442382, -1876419.8396889826
3847971.9369461425, -1876428.566456088 3847971.703829692,
-1876437.1638362387 3847973.497051448, -1876445.3014369362
3847977.2476997958, -1876462.1476702257 3847995.346476615,
-1876479.0519202838 3848020.8695257055, -1876498.5251660557
3848038.6726656007, -1876513.8057426987 3848053.8755431217,
-1876526.8713291166 3848071.158459993, -1876536.4705924124
3848088.8048734763, -1876544.474504419 3848103.1186408913))
POLYGON ((-1876188.5041804744 3848441.382478181, -1876213.8676121181
3848430.846339705, -1876232.2128869023 3848442.867444207,
-1876255.1156938097 3848448.391229029, -1876263.7170912437
3848446.625315366, -1876271.8631297487 3848442.900441352,
-1876279.2407616368 3848437.3597535645, -1876286.3166743552
3848428.9527952927, -1876295.3121583033 3848406.0858179284,
-1876322.3367223463 3848371.7842661925, -1876338.9274128082
3848362.1980404467, -1876352.1625399927 3848341.9048215672,
-1876355.8397513435 3848325.7032860224, -1876392.7014745248
3848280.240130746, -1876408.3034239912 3848271.162037587,
-1876419.7925063348 3848255.6842517625, -1876425.3492611286
3848236.5173345227, -1876448.8350632659 3848194.056099103,
-1876497.9576754894 3848176.626671925, -1876511.5703764597
3848175.706514713, -1876532.1635244589 3848163.5079068835,
-1876538.0494765278 3848155.8526974116, -1876542.564784783
3848146.9808798665, -1876545.5359284605 3848137.233395549,
-1876546.7289264835 3848127.920085206, -1876543.8326752747
3848105.2191006835, -1876544.474504419 3848103.1186408913,
-1876555.364968197 3848122.594562845, -1876613.1520997677
3848162.3675248004, -1876643.7440328614 3848164.0146221793,
-1876663.6927700208 3848164.5011996846, -1876683.192810332
3848167.12801539, -1876694.3396283644 3848172.942206207, -1876729.222851098
3848184.6999077704, -1876752.1308707832 3848189.0236756955,
-1876775.2079730928 3848194.8107520035, -1876798.5387789228
3848201.0402887687, -1876818.0078754043 3848207.757704202,
-1876825.5168982225 3848213.0434713834, -1876832.0133303176
3848219.9674387504, -1876842.4662997134 3848244.3378965603,
-1876843.2054359675 3848261.707224046, -1876861.2688388631
3848312.1439763256, -1876871.8038666635 3848328.5512987934,
-1876875.150448244 3848340.4371598824, -1876876.0940030015
3848353.6814036234, -1876917.9312230255 3848439.868789222,
-1876970.7508031656 3848459.9319257336, -1876979.40250072
3848458.555547057, -1876990.0006676659 3848459.8050995087,
-1877008.4619106373 3848470.1297051855, -1877017.0955844864
3848480.5056134313, -1877021.477160249 3848489.4717585254,
-1877024.301687109 3848499.280817776, -1877025.4606200766
3848509.5558361392, -1877024.909422015 3848519.9019511133,
-1877022.669275147 3848529.921566969, -1877018.8262670683
3848539.2296341895, -1877003.2592212302 3848556.884851514,
-1876985.3633999326 3848594.025260806, -1876984.2504019388
3848618.3515737974, -1876979.8689933338 3848630.673808795,
-1876974.6526896537 3848638.986054786, -1876955.3251426958
3848657.1895378665, -1876935.583089114 3848679.1664741687,
-1876927.8490822841 3848695.4257583003, -1876921.5969562072 3848702.660283,
-1876902.5348853646 3848721.058174326, -1876883.9019792771
3848742.645870728, -1876875.3838462024 3848755.907305373,
-1876868.424151412 3848762.1645327415, -1876860.5703416185
3848766.688968825, -1876838.0377610966 3848776.5621749186,
-1876829.349730498 3848779.224651684, -1876804.5796488456
3848783.971908446, -1876780.5805599443 3848791.596718001,
-1876756.9410378663 3848792.3356899554, -1876734.2644018286
3848790.4642326944, -1876700.3784324513 3848803.482909626,
-1876682.0011088175 3848816.599862887, -1876659.4327815596
3848827.5909101143, -1876639.8917685184 3848833.594604695,
-1876635.4473263393 3848834.676561093, -1876610.7716336164
3848839.142003935, -1876591.586251268 3848842.613892571,
-1876582.8695489783 3848843.1634326293, -1876574.230066107
3848841.6827377453, -1876553.9240153476 3848828.052519444,
-1876544.9651251037 3848813.196665439, -1876541.8119837304
3848802.7424316006, -1876540.8592023957 3848798.2993606455,
-1876463.435636762 3848723.940778296, -1876454.556063145 3848721.752043542,
-1876439.7054872836 3848713.513660915, -1876340.6009741211
3848712.0397475157, -1876336.9716249965 3848714.6697668843,
-1876325.1425350858 3848722.0441130563, -1876309.358982446
3848728.9070836334, -1876289.1966581808 3848731.4656279325,
-1876282.3878467309 3848730.430180864, -1876274.1122191094
3848727.132655977, -1876266.5372747388 3848721.981034509,
-1876259.9541144758 3848715.1732926485, -1876254.6157254823
3848706.971050703, -1876241.4056594612 3848681.0851763617,
-1876233.2071627886 3848671.207664653, -1876228.4184083748
3848661.9271781407, -1876225.3308779148 3848651.678906895,
-1876225.8657088026 3848625.151777304, -1876232.4587040814
3848603.8166017733, -1876237.1606100549 3848593.5774464393,
-1876210.762329093 3848506.44601509, -1876201.7365914446
3848499.3614434074, -1876189.2612409296 3848478.9384858515,
-1876188.0137353514 3848475.60259037, -1876186.0950818309
3848465.489351611, -1876185.8745866169 3848455.1259033694,
-1876187.3607232203 3848444.9105072804, -1876188.5041804744
3848441.382478181))
On Fri, Mar 27, 2020 at 4:08 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hi,
> I finally got to test this situation a bit more. The culprit seems to be
> the Union process:
> with this to get all rings from the polygons, and which return their
> linestrings in full precision:
> create materialized view isolated_polygons as (
> select st_exteriorring((st_dumprings((st_dump(geom)).geom)).geom) as geom
> from OUTPUTS_FINAIS.estabelecimentos_as_400
> All these produced a reduced precision output:
> create materialized view boundaries as
> SELECT ST_Union(geom) AS geom
> create materialized view boundaries2 as
> SELECT ST_UnaryUnion(st_collect(geom)) AS geom
> create materialized view boundaries3 as
> SELECT ST_MemUnion(geom) AS geom
> BTW, my data is in EPSG:4326
> I am now trying to convert data to another EPSG, to see what happens.
> Thanks,
> Alexandre Neto
> On Tue, Mar 17, 2020 at 4:19 PM Alexandre Neto <senhor.neto at gmail.com>
> wrote:
>> I will, thank you!
>> On Tue, Mar 17, 2020 at 4:10 PM Martin Davis <mtnclimb at gmail.com> wrote:
>>> It seems odd that precision is being reduced that much.  In order to
>>> isolate where it is happening, you should capture output from each stage of
>>> the CTE (which is easy to do, by just truncating the CTE after each query
>>> and doing a "SELECT * FROM cte_tbl" .  Then post the results here if you
>>> need help analyzing them, and so we can investigate further.
>>> Even better would be to provide the dataset which is causing the
>>> problem, to aid in sorting this out.
>>> On Mon, Mar 16, 2020 at 7:16 PM Alexandre Neto <senhor.neto at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am running a Overlay analysis, and I am following what is proposed by
>>>> Paul Ramsey in this article:
>>>> http://blog.cleverelephant.ca/2019/07/postgis-overlays.html
>>>> I am using this query on PostgreSQL 10 and PostGIS
>>>> With isolated_polygons as
>>>> geom
>>>> , boundaries as (
>>>> SELECT st_union(geom) AS geom
>>>> , poligonos as (
>>>> FROM boundaries
>>>> , n_poligonos as (
>>>> SELECT row_number() over() as id, geom
>>>> FROM poligonos
>>>> SELECT p.id, count(id) as n_sobreposicoes,
>>>> p.geom::geometry(polygon,4326)
>>>> into temp.sobreposicoes_400m
>>>> FROM n_poligonos as p
>>>> join outputs_finais.estabelecimentos_as_400 as t
>>>> on st_contains(t.geom,st_pointonsurface(p.geom))
>>>> GROUP BY id, p.geom;
>>>> When I use this with a sample set of input multipolygons, The results
>>>> are what we would expect, all the overlapping polygons split and the count
>>>> of the number of overlapping polygons.
>>>> When I run it with the full set (around 4800 polygons)
>>>> The precison of the output polygons gets truncated and instead of
>>>> detailed polygons I get a "pixelied" output:
>>>> POLYGON ((-8.99 39.42, -8.99 39.43, -8.98 39.43, -8.97 39.43, -8.97
>>>> 39.42, -8.98 39.42, -8.99 39.42))
>>>> POLYGON ((-8.19 39.56, -8.2 39.56, -8.2 39.57, -8.19 39.57, -8.18
>>>> 39.57, -8.19 39.56))
>>>> POLYGON ((-8.54 41.02, -8.55 41.02, -8.55 41.03, -8.54 41.03, -8.54
>>>> 41.02))
>>>> POLYGON ((-8.39 40.17, -8.4 40.17, -8.4 40.18, -8.39 40.18, -8.39
>>>> 40.17))
>>>> POLYGON ((-8.57 38.83, -8.58 38.83, -8.59 38.84, -8.58 38.84, -8.57
>>>> 38.84, -8.57 38.83))
>>>> My gut feeling is that this is happening at the polygonize level, but I
>>>> am not sure.
>>>> I have also tried to use st_node + st_collect getting the same kind of
>>>> results
>>>> Any idea of what can this be?
>>>> Since not all polygons are overlapping each other, I wanted to try to
>>>> separate the analysis by chunks, but I fail to see how can I union or
>>>> collect only not disjoint line groups.
>>>> I am using
>>>> PostgreSQL 10.12 (Ubuntu 10.12-0ubuntu0.18.04.1) on
>>>> x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0,
>>>> 64-bit
>>>> POSTGIS="2.5.3 r17699" [EXTENSION] PGSQL="100" GEOS="3.7.1-CAPI-1.11.1
>>>> 27a5e771" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL 2.2.3, released
>>>> 2017/11/20" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.2.1" RASTER
>>>> Thanks,
>>>> Alexandre Neto
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200327/fc6046ee/attachment.html>
