[postgis-users] ERROR: distance returned negative!
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri May 1 13:38:38 PDT 2020
There is a hint on what's happening. Someone pressed Ctrl+C, so the rest of
the message is just whatever debug messages there are on the way out of the
function that processed the Ctrl+C.
NOTICE:  liblwgeom code interrupted
It also happens some times that Ctrl+C interrupt flag does not get reset,
so you get this message in the next query after you cancelled one before. A
reproducer scenario on that would be valuable.
On Fri, May 1, 2020 at 11:27 PM Christophe Pettus <xof at thebuild.com> wrote:
> > On May 1, 2020, at 13:26, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> > Honestly, this is very rare, as in I haven't seen it before...
> Exciting!  OK, off I go to get a reproducer.  Thank you!
> -- Christophe Pettus
>    xof at thebuild.com
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200501/f2f9055a/attachment.html>
