[postgis-users] Dependencies for postgis25_12 not found (geos38, proj70)
Regina Obe lr at pcorp.us
Wed May 6 06:40:16 PDT 2020
Sounds like a packaging mistake.  Both 3.8.1 and proj79 are stable so it is possible they just weren’t pushed to stable branch.
Probably best to report this to yum list -  https://www.postgresql.org/list/pgsql-pkg-yum/
Which I have cc’d here.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Steve Pritchard
Sent: Wednesday, May 6, 2020 9:04 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] Dependencies for postgis25_12 not found (geos38, proj70)
I tried to install Postgres 12.2 with PostGIS 2.5 on Centos 7.7 today, but yum was unable to find the necessary dependencies for postgis25_12:
Error: Package: postgis25_12-client-2.5.4-1.rhel7.x86_64 (pgdg12)
           Requires: libproj.so.19()(64bit)
Error: Package: postgis25_12-2.5.4-1.rhel7.x86_64 (pgdg12)
           Requires: proj70 >= 7.0.0
           Requires: geos38 >= 3.8.1
           Installed: geos38-3.8.0-1.rhel7.x86_64 (@pgdg10)
               geos38 = 3.8.0-1.rhel7
The required packages geos38 (3.8.1) and  proj70 (7.0.0) don't seem to be in either:
*	PostgreSQL Yum Repository
*	EPEL
Having hunted around, I finally found them in https://ftp.postgresql.org/pub/repos/yum/testing/common/redhat/rhel-7-x86_64/, however as I understand it, the packages in the "testing" repo should not be used in production (c.f. comment in .repo file).
Why do the postgis25_12 production packages have dependencies on packages that only seem to be available from a 'testing' repository?
Or should  geos38 (3.8.1) and  proj70 (7.0.0) be available from the production repositories?
Steve Pritchard
Steve Pritchard
Database Developer
British Trust for Ornithology, The Nunnery, Thetford, Norfolk IP24 2PU, UK
Tel: +44 (0)1842 750050, fax: +44 (0)1842 750030
Registered Charity No 216652 (England & Wales) No SC039193 (Scotland)
Company Limited by Guarantee No 357284 (England & Wales)
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200506/45aa41ae/attachment.html>
