[postgis-users] Problem with "undefined symbol: GEOSMakeValid_r"
Marco Boeringa
marco at boeringa.demon.nl
Wed May 6 07:56:49 PDT 2020
Hi all,
I hope someone has a recommendation for how to solve this:
When I attempted to upgrade my 19.10 Ubuntu installation to 20.04, I
first ran into an issue that I couldn't run the Ubuntu upgrade
installer, unless I uninstalled PostGIS 2.5 first. It complained about
PostGIS being on the "black list for removal" or something similar. So,
I finally decided to uninstall the PostGIS 2.5 through the Synaptics
Package manager of Ubuntu, after which I was able to upgrade to 20.04 Focal.
I then attempted to re-install PostGIS 2.5 from the Synaptic Pacakage
manager again. After several attempts, I now have it installed, and I
can access spatial data from the existing PostgreSQL 11 database using
e.g. DBeaver.
However, as part of my code, I had a call to the
"PostGIS_Full_Version()" function, and that now fails with the error
attached below. Is this still an indication the PostGIS 2.5 install is
somehow broken? I have already tried to re-install "libgdal26", as is
referenced in the error message, but to no avail.
I have also attempted to install the "postgresql-11-postgis-3" and
"postgresql-11-postgis-3-scripts" packages, in the hope of being able to
solve the issue by upgrading PostGIS, but that failed as well, with
Synaptic showing an error message and complaining about a shared library
/ application that is also in the PostGIS 2.5 install and that "could
not be overwritten" (file
"usr/share/postgresql/11/applications/shp2pgsql-gui.desktop")
Marco
SQL Error [XX000]: ERROR: could not load library
"/usr/lib/postgresql/11/lib/rtpostgis-2.5.so": /usr/lib/libgdal.so.26:
Where: SQL statement "SELECT public.postgis_gdal_version()"
PL/pgSQL function postgis_full_version() line 34 at SQL statement
