[postgis-users] Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Marco Boeringa marco at boeringa.demon.nl
Wed May 13 05:51:01 PDT 2020
Thanks for the response Tom, but could you be a bit more specific?
What do you mean with "Same problem with qgis"? Do you mean you've also
encountered a "undefined symbol: GEOSMakeValid" error related to the
"postgis-3.so" library when trying to use some tool in QGIS?
I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu
20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter
the error.
Marco
Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
> On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl
> <mailto:marco at boeringa.demon.nl>> wrote:
>     Hi all,
>     Is there someone who can confirm they have been able to install
>     PostGIS
>     3.0.1 via the official APT repository?:
>     https://wiki.postgresql.org/wiki/Apt
>     After using the Synaptics Package Manager to install the three
>     packages
>     involved
>     ("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
>     and subsequently trying to create the PostGIS extension in
>     pgAdmin4, I
>     get the following error:
>     ERROR: could not load library
>     "/usr/lib/postgresql/12/lib/postgis-3.so":
>     /usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol:
>     GEOSMakeValid
>     I have been trying different things to fix this for past two days
>     including re-install, but to no avail. I have also attempted to
>     include
>     the UbuntuGIS repository as a potential alternative resource of
>     PostGIS
>     packages, but discovered the UbuntuGIS repository is lagging
>     behind and
>     doesn't yet have packages for 20.04LTS.
>     Marco
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200513/0e51e712/attachment.html>
