[postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
Regina Obe lr at pcorp.us
Fri May 15 04:24:56 PDT 2020
Yes stray doc.  Did you find this via google.  Looks like that page last got updated 4/17/2019.   It’s the nature of how we build the docs that the updates overwrite existing for a particular Minor version, but don’t delete.
So it existed early in the life cycle of 3.0 but was later removed
Anyway I’ve deleted ST_Length2D_Spheroid.html and ST_Point_Inside_Circle.html which also seemed to have the same issue
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Darafei "Kom?pa" Praliaskouski
Sent: Friday, May 15, 2020 5:55 AM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Fwd: Re: Broken installs for PostGIS for Ubuntu 20.04LTS / Focal?
It is mentioned in changelog and removed from the docs. For some reason there is stray page from older release.
On Fri, May 15, 2020 at 12:52 PM Tom van Tilburg <tom.van.tilburg at gmail.com <mailto:tom.van.tilburg at gmail.com> > wrote:
It's the first thing I ran into as well after upgrading .
But it hasn't been mentioned in the docs? Whoops... time for an issue...
Tom
On Fri, May 15, 2020 at 10:56 AM Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Tom,
It now appears the PostGIS team indeed removed 'ST_Accum', but forgot to update the online PostGIS Help. I see two OSGEO tickets related to this:
https://trac.osgeo.org/postgis/ticket/4356
https://trac.osgeo.org/postgis/changeset/17397
Both mention replacing 'ST_Accum' with 'array_agg'.
Marco
Op 15-5-2020 om 10:38 schreef Marco Boeringa:
Tom,
One more question:
After successfully installing the PostGIS 3.0.1 extension using CREATE EXTENSION in pgAdmin4 on PostgreSQL 12.3 on Ubuntu 20.04 Focal, I now ran into an issue where it appears the 'ST_Accum' function is missing in my PostGIS install. My code calls this, and it failed. I then had a look at the function list in pgAdmin, and indeed 'ST_Accum' is not listed. I do see loads of other PostGIS functions, just 'ST_Accum' seems missing (although I cannot garantuee there are a few more missing functions, but the list seems pretty comprehensive from a quick look, and the CREATE EXTENSION call went without a hitch).
Can you confirm you see 'ST_Accum' in your PostGIS 3.0.1 function list if you look in pgAdmin? The PostGIS Help does not mention some deprecation of this function:
https://postgis.net/docs/ST_Accum.html
Marco
Op 14-5-2020 om 11:42 schreef Tom van Tilburg:
Whatever lives in /usr/local/lib was my manual build so I had to delete that manually.
I did  `sudo rm /usr/local/lib/libgeos*` (same for proj and sfcgal)
On top of that I purged all old package configurations `sudo apt purge <packagename>` just to be sure but I don't think it is needed.
Best,
 Tom
On Thu, May 14, 2020 at 10:45 AM Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Hi Tom,
Thanks for the tip, but what did you do to remove the old install? Did you rely on Apt or Synaptic to remove the old libgeos version, or did you manually clean up folders? I had two versions of libgeos as well (3.7 and 3.8) if I remember well (need to start up the VM again to check), and removed the older one through Synaptic just leaving the 3.8 version, but that wasn't enough to solve my particular issues.
Marco
Op 14-5-2020 om 10:32 schreef Tom van Tilburg:
I think I solved it.
The issue lies with gdal, not postgis (test by running `gdalinfo`), and it turns out there was an old install of libgeos (3.7) in my /us/local/lib. After simply removing all related files in /usr/local/lib gdal (and postgis and qgis) stopped complaining (I had to remove old installs of geos, proj and sfcgal for that).
This issue put me on the right track:
https://github.com/OSGeo/gdal/issues/2214
T.
On Wed, May 13, 2020 at 3:15 PM Marco Boeringa <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Thanks Tom,
I have seen a similar error related to the "libgdal26" library, but that was after other trials to get something running on Ubuntu 20.04 Focal, where I successfully installed PostGIS 2.5.4, but then encountered issues when my code called the "postgis_full_version()" function and errored out with the error message below related to the "libgdal.so.26" library. However, as said, this was with PostGIS 2.5.4, not with the PostGIS 3.0.1 I actually want to install at this moment and that gave the other error related to the "postgis-3.so" library.
SQL Error [XX000]: ERROR: could not load library "/usr/lib/postgresql/11/lib/rtpostgis-2.5.so <http://rtpostgis-2.5.so> ": /usr/lib/libgdal.so.26: undefined symbol: GEOSMakeValid_r
  Where: SQL statement "SELECT public.postgis_gdal_version()"
PL/pgSQL function postgis_full_version() line 34 at SQL statement
Marco
Sorry for the short answer, am on the way currently. Will try to do a decent report tonight.
Error is roughly the same but comes from libgdal26 in my case when doing apt install qgis after an upgrade to 20.04.
best, Tom
On Wed, 13 May 2020, 14:48 Marco Boeringa, <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Thanks for the response Tom, but could you be a bit more specific?
What do you mean with "Same problem with qgis"? Do you mean you've also encountered a "undefined symbol: GEOSMakeValid" error related to the "postgis-3.so" library when trying to use some tool in QGIS?
I have installed PostgreSQL 12 and PostGIS 3.0.1 via Synaptic on Ubuntu 20.04 (Focal) and use CREATE EXTENSION (via pgAdmin4), when I encounter the error.
Marco
Op 13-5-2020 om 14:40 schreef Tom van Tilburg:
On Wed, 13 May 2020, 11:14 Marco Boeringa, <marco at boeringa.demon.nl <mailto:marco at boeringa.demon.nl> > wrote:
Hi all,
Is there someone who can confirm they have been able to install PostGIS
3.0.1 via the official APT repository?:
https://wiki.postgresql.org/wiki/Apt
After using the Synaptics Package Manager to install the three packages
involved
("postgresql-12-postgis-3"/"postgresql-12-postgis-3-dbgsym"/"postgresql-12-postgis-3-scripts"),
and subsequently trying to create the PostGIS extension in pgAdmin4, I
get the following error:
ERROR: could not load library "/usr/lib/postgresql/12/lib/postgis-3.so":
/usr/lib/postgresql/12/lib/postgis-3.so: undefined symbol: GEOSMakeValid
I have been trying different things to fix this for past two days
including re-install, but to no avail. I have also attempted to include
the UbuntuGIS repository as a potential alternative resource of PostGIS
packages, but discovered the UbuntuGIS repository is lagging behind and
doesn't yet have packages for 20.04LTS.
Marco
postgis-users mailing list
postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/postgis-users
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200515/a6e61e9f/attachment.html>
