[postgis-users] Problem raster2pgsql on Centos 8 - postgres 12 / postgis 2.5
Regina Obe
lr at pcorp.us
Wed Nov 4 14:05:22 PST 2020
Sounds from the below thread the issue is with proj and the interaction with
GDAL.
Can both of you let me know what the output of
SELECT postgis_full_version()l
Gives - and also do an
ldd raster2pgsql
ldd postgis-2.5.so #probably need to specify full path
There have been many changes in proj and while we patched it in for general
postgis vector use in 3.0, 3.1+
Depending on you mix of GDAL version and Proj. Those 2 might be
incompatible.
GDAL < 3 should ideally be using a Proj < 6
GDAL > 3 should be using proj >= 6 and by extension so should PostGIS.
Both PostGIS and GDAL should be using the same version of proj otherwise bad
things happen.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Lars Aksel Opsahl
Sent: Monday, November 2, 2020 4:29 AM
To: postgis-users at lists.osgeo.org
Subject: Re: [postgis-users] Problem raster2pgsql on Centos 8 - postgres 12
/ postgis 2.5
_____
>From: postgis-users <postgis-users-bounces at lists.osgeo.org
<mailto:postgis-users-bounces at lists.osgeo.org> > on behalf of Alain Benard
<alain.benard at inrae.fr <mailto:alain.benard at inrae.fr> >Sent: Monday,
November 2, 2020 9:17 AMTo: postgis-users at lists.osgeo.org
<mailto:postgis-users at lists.osgeo.org> <postgis-users at lists.osgeo.org
<mailto:postgis-users at lists.osgeo.org> >Subject: [postgis-users] Problem
>Hi ,
>I have a problem with rasterpgsql with all file geotiff.
>On a server Centos 7 / Postgres 9.5 / postgis 2.5 :
>/usr/pgsql-9.5/bin/raster2pgsql -b 1 -I -C -F -t 50x50 -s 2154
filename.geotiff tablename > script.sql : it's OK.
>On a server Centos 8 / Postgres 12 / postgis 2.5 : (with the same geotiff
file)
> /usr/pgsql-12/bin/raster2pgsql -b 1 -I -C -F -t 50x50 -s
2154 filename.geotiff tablename > script.sql : error
>The script.sql file is not completed and the error is :
> free(): invalid pointer
>Abandon (core dumped)
>I search on the web but nobody give solution (except work on Centos 7 L)
>Thanks for advance.
>Alain.
Here is some info for the same problem related but for Postgis 3.0
<https://www.postgresql-archive.org/free-invalid-pointer-when-to-dumping-dat
a-to-a-new-server-td6159235.html>
https://www.postgresql-archive.org/free-invalid-pointer-when-to-dumping-data
<https://trac.osgeo.org/postgis/ticket/4779>
<https://redmine.postgresql.org/issues/5961>
Lars
<http://www.inra.fr/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201104/fd06e556/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201104/fd06e556/attachment.png>
