[postgis-users] Problem raster2pgsql on Centos 8 - postgres 12 / postgis
Alain Benard alain.benard at inrae.fr
Fri Nov 6 01:53:50 PST 2020
From: "Regina Obe" <lr at pcorp.us<mailto:lr at pcorp.us>>
     Sounds from the below thread the issue is with proj and the interaction with GDAL.
     Can both of you let me know what the output of
     SELECT postgis_full_version()
     Gives - and also do an
        ldd raster2pgsql
        ldd postgis-2.5.so  #probably need to specify full path
     There have been many changes in proj and while we patched it in for general postgis vector use in 3.0, 3.1+
     Depending on you mix of GDAL version and Proj.  Those 2 might be incompatible.
     GDAL < 3  should ideally be using a Proj < 6
     GDAL > 3 should be using proj >= 6  and by extension so should PostGIS.
     Both PostGIS and GDAL should be using the same version of proj otherwise bad things happen.
 thank you Regina and Lars for your response.
I would precise i did never compil any packet.
Installation server history (Centos 8) :
        postgres : (https://www.postgresql.org/download/linux/redhat/)
                dnf -y install https://download.postgresql.org/pub/repos/yum/reporpms/EL-8-x86_64/pgdg-redhat-repo-latest.noarch.rpm
                dnf -qy module disable postgresql
                dnf -y install postgresql12-server postgresql12-devel postgresql12-contrib
        postgis : (https://computingforgeeks.com/how-to-install-postgis-on-centos-8-linux/)
                dnf -y install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm
                dnf config-manager --set-enabled PowerTools
                dnf -y install postgis25_12 postgis25_12-docs postgis25_12-utils postgis25_12-client
SELECT postgis_full_version() :
        POSTGIS="2.5.5" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3" PROJ="Rel. 6.3.2, May 1st, 2020" GDAL="GDAL 3.1.3, released 2020/09/01" LIBXML="2.9.7" LIBJSON="0.13.1" LIBPROTOBUF="1.3.0" TOPOLOGY RASTER
ldd /usr/pgsql-12/bin/raster2pgsql
        linux-vdso.so.1 (0x00007ffe013cb000)
        liblwgeom-2.5.so.0 => /usr/pgsql-12/lib/liblwgeom-2.5.so.0 (0x00007f222cedc000)
        libgdal.so.27 => /usr/gdal31/lib/libgdal.so.27 (0x00007f222b4f1000)
        libgeos_c.so.1 => /usr/geos38/lib64/libgeos_c.so.1 (0x00007f222b2b4000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f222aef2000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f222ab70000)
        libproj.so.19 => /usr/proj71/lib/libproj.so.19 (0x00007f222a65d000)
        libjson-c.so.4 => /lib64/libjson-c.so.4 (0x00007f222a44d000)
        libSFCGAL.so.1 => /lib64/libSFCGAL.so.1 (0x00007f2229756000)
        libarmadillo.so.9 => /lib64/libarmadillo.so.9 (0x00007f2229545000)
        libpoppler.so.78 => /lib64/libpoppler.so.78 (0x00007f222905f000)
        libfreexl.so.1 => /lib64/libfreexl.so.1 (0x00007f2228e55000)
        libwebp.so.7 => /lib64/libwebp.so.7 (0x00007f2228be7000)
        libodbc.so.2 => /lib64/libodbc.so.2 (0x00007f2228976000)
        libodbcinst.so.2 => /lib64/libodbcinst.so.2 (0x00007f2228760000)
        libexpat.so.1 => /lib64/libexpat.so.1 (0x00007f2228525000)
        libxerces-c-3.2.so => /lib64/libxerces-c-3.2.so (0x00007f2227f52000)
        libopenjp2.so.7 => /lib64/libopenjp2.so.7 (0x00007f2227d00000)
        libjasper.so.4 => /lib64/libjasper.so.4 (0x00007f2227aa2000)
        libnetcdf.so.15 => /lib64/libnetcdf.so.15 (0x00007f2227756000)
        libhdf5.so.103 => /lib64/libhdf5.so.103 (0x00007f22271cb000)
        libmfhdf.so.0 => /lib64/libmfhdf.so.0 (0x00007f2226fa2000)
        libdf.so.0 => /lib64/libdf.so.0 (0x00007f2226cf9000)
        libogdi.so.4 => /lib64/libogdi.so.4 (0x00007f2226adc000)
        libgif.so.7 => /lib64/libgif.so.7 (0x00007f22268d2000)
        libjpeg.so.62 => /lib64/libjpeg.so.62 (0x00007f2226669000)
        libgeotiff.so.5 => /lib64/libgeotiff.so.5 (0x00007f2226435000)
        libtiff.so.5 => /lib64/libtiff.so.5 (0x00007f22261bc000)
        libgta.so.1 => /lib64/libgta.so.1 (0x00007f2225fb2000)
        libpng16.so.16 => /lib64/libpng16.so.16 (0x00007f2225d7d000)
        libcfitsio.so.7 => /lib64/libcfitsio.so.7 (0x00007f2225872000)
        libpq.so.5 => /usr/pgsql-12/lib/libpq.so.5 (0x00007f2225623000)
        libzstd.so.1 => /lib64/libzstd.so.1 (0x00007f2225381000)
        liblzma.so.5 => /lib64/liblzma.so.5 (0x00007f222515a000)
        libproj.so.15 => /lib64/libproj.so.15 (0x00007f2224c4a000)
        libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007f2224937000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f222472e000)
        libtirpc.so.3 => /lib64/libtirpc.so.3 (0x00007f22244fb000)
        libdapclient.so.6 => /lib64/libdapclient.so.6 (0x00007f22242b1000)
        libdapserver.so.7 => /lib64/libdapserver.so.7 (0x00007f22240a0000)
        libdap.so.25 => /lib64/libdap.so.25 (0x00007f2223ce4000)
        libspatialite.so.7 => /lib64/libspatialite.so.7 (0x00007f22234a9000)
        libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f2223238000)
        libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f2222faa000)
        libxml2.so.2 => /lib64/libxml2.so.2 (0x00007f2222c42000)
        libmariadb.so.3 => /lib64/libmariadb.so.3 (0x00007f22229f0000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f22227d9000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f22225d5000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f22223b5000)
        libssl.so.1.1 => /lib64/libssl.so.1.1 (0x00007f2222121000)
        libcrypto.so.1.1 => /lib64/libcrypto.so.1.1 (0x00007f2221c3e000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f22218a9000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f222d184000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f2221691000)
        libgeos-3.8.1.so => /usr/geos38/lib64/libgeos-3.8.1.so (0x00007f22212bc000)
        libCGAL_Core.so.13 => /usr/lib64/libCGAL_Core.so.13 (0x00007f222101c000)
        libboost_thread.so.1.66.0 => /usr/lib64/libboost_thread.so.1.66.0 (0x00007f2220df0000)
        libboost_system.so.1.66.0 => /usr/lib64/libboost_system.so.1.66.0 (0x00007f2220beb000)
        libboost_serialization.so.1.66.0 => /usr/lib64/libboost_serialization.so.1.66.0 (0x00007f22209aa000)
        libboost_chrono.so.1.66.0 => /usr/lib64/libboost_chrono.so.1.66.0 (0x00007f22207a1000)
        libboost_date_time.so.1.66.0 => /usr/lib64/libboost_date_time.so.1.66.0 (0x00007f222058e000)
        libboost_atomic.so.1.66.0 => /usr/lib64/libboost_atomic.so.1.66.0 (0x00007f222038c000)
        libCGAL.so.13 => /usr/lib64/libCGAL.so.13 (0x00007f222016d000)
        libmpfr.so.4 => /usr/lib64/libmpfr.so.4 (0x00007f221ff09000)
        libgmp.so.10 => /usr/lib64/libgmp.so.10 (0x00007f221fc71000)
        libopenblaso.so.0 => /lib64/libopenblaso.so.0 (0x00007f221df27000)
        liblapack.so.3 => /lib64/liblapack.so.3 (0x00007f221d686000)
        libsz.so.2 => /lib64/libsz.so.2 (0x00007f221d483000)
        libarpack.so.2 => /lib64/libarpack.so.2 (0x00007f221d235000)
        libsuperlu.so.5.1 => /lib64/libsuperlu.so.5.1 (0x00007f221cfbf000)
        libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007f221cd03000)
        libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007f221cabe000)
        libsmime3.so => /lib64/libsmime3.so (0x00007f221c895000)
        libnss3.so => /lib64/libnss3.so (0x00007f221c55f000)
        libnspr4.so => /lib64/libnspr4.so (0x00007f221c31e000)
        liblcms2.so.2 => /lib64/liblcms2.so.2 (0x00007f221c0c1000)
        libltdl.so.7 => /lib64/libltdl.so.7 (0x00007f221beb7000)
        libhdf5_hl.so.100 => /lib64/libhdf5_hl.so.100 (0x00007f221bc93000)
        libjbig.so.2.1 => /lib64/libjbig.so.2.1 (0x00007f221ba87000)
        libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f221b876000)
        libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f221b626000)
        libldap_r-2.4.so.2 => /lib64/libldap_r-2.4.so.2 (0x00007f221b3d0000)
        libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f221b0e0000)
        libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f221aec4000)
        libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f221acc0000)
        libuuid.so.1 => /lib64/libuuid.so.1 (0x00007f221aab8000)
        libnghttp2.so.14 => /lib64/libnghttp2.so.14 (0x00007f221a891000)
        libidn2.so.0 => /lib64/libidn2.so.0 (0x00007f221a673000)
        libssh.so.4 => /lib64/libssh.so.4 (0x00007f221a3e8000)
        libpsl.so.5 => /lib64/libpsl.so.5 (0x00007f221a1d7000)
        libldap-2.4.so.2 => /lib64/libldap-2.4.so.2 (0x00007f2219f8a000)
        liblber-2.4.so.2 => /lib64/liblber-2.4.so.2 (0x00007f2219d7a000)
        libbrotlidec.so.1 => /lib64/libbrotlidec.so.1 (0x00007f2219b6e000)
        libgfortran.so.5 => /lib64/libgfortran.so.5 (0x00007f22196f1000)
        libgomp.so.1 => /lib64/libgomp.so.1 (0x00007f22194b9000)
        libblas.so.3 => /lib64/libblas.so.3 (0x00007f2219265000)
        libaec.so.0 => /lib64/libaec.so.0 (0x00007f221905d000)
        libopenblasp.so.0 => /lib64/libopenblasp.so.0 (0x00007f2217312000)
        libquadmath.so.0 => /lib64/libquadmath.so.0 (0x00007f22170d1000)
        libsatlas.so.3 => /usr/lib64/atlas/libsatlas.so.3 (0x00007f22162f6000)
        libnssutil3.so => /lib64/libnssutil3.so (0x00007f22160c5000)
        libplc4.so => /lib64/libplc4.so (0x00007f2215ec0000)
        libplds4.so => /lib64/libplds4.so (0x00007f2215cbc000)
        libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f2215aab000)
        libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f22158a7000)
        libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f2215690000)
        libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007f2215472000)
        libunistring.so.2 => /lib64/libunistring.so.2 (0x00007f22150f1000)
        libbrotlicommon.so.1 => /lib64/libbrotlicommon.so.1 (0x00007f2214ed1000)
        libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f2214ca6000)
        libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f2214a7d000)
        libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007f22147f9000)
ldd /usr/pgsql-12/lib/postgis-2.5.so
        linux-vdso.so.1 (0x00007fff426f6000)
        libgeos_c.so.1 => /usr/geos38/lib64/libgeos_c.so.1 (0x00007f9c081b7000)
        libproj.so.15 => /lib64/libproj.so.15 (0x00007f9c07ca7000)
        libjson-c.so.4 => /lib64/libjson-c.so.4 (0x00007f9c07a97000)
        libprotobuf-c.so.1 => /lib64/libprotobuf-c.so.1 (0x00007f9c0788e000)
        libxml2.so.2 => /lib64/libxml2.so.2 (0x00007f9c07526000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f9c071a4000)
        libSFCGAL.so.1 => /lib64/libSFCGAL.so.1 (0x00007f9c064ad000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f9c060eb000)
        libgeos-3.8.1.so => /usr/geos38/lib64/libgeos-3.8.1.so (0x00007f9c05d16000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f9c05981000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f9c05769000)
        libsqlite3.so.0 => /lib64/libsqlite3.so.0 (0x00007f9c05456000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f9c05236000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f9c086e0000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f9c05032000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f9c04e1b000)
        liblzma.so.5 => /lib64/liblzma.so.5 (0x00007f9c04bf4000)
        libCGAL_Core.so.13 => /usr/lib64/libCGAL_Core.so.13 (0x00007f9c04954000)
        libboost_thread.so.1.66.0 => /usr/lib64/libboost_thread.so.1.66.0 (0x00007f9c04728000)
        libboost_system.so.1.66.0 => /usr/lib64/libboost_system.so.1.66.0 (0x00007f9c04523000)
        libboost_serialization.so.1.66.0 => /usr/lib64/libboost_serialization.so.1.66.0 (0x00007f9c042e2000)
        libboost_chrono.so.1.66.0 => /usr/lib64/libboost_chrono.so.1.66.0 (0x00007f9c040d9000)
        libboost_date_time.so.1.66.0 => /usr/lib64/libboost_date_time.so.1.66.0 (0x00007f9c03ec6000)
        libboost_atomic.so.1.66.0 => /usr/lib64/libboost_atomic.so.1.66.0 (0x00007f9c03cc4000)
        libCGAL.so.13 => /usr/lib64/libCGAL.so.13 (0x00007f9c03aa5000)
        libmpfr.so.4 => /usr/lib64/libmpfr.so.4 (0x00007f9c03841000)
        libgmp.so.10 => /usr/lib64/libgmp.so.10 (0x00007f9c035a9000)
        librt.so.1 => /usr/lib64/librt.so.1 (0x00007f9c033a0000)
I can precise that recently (after dnf upgrade) we need to downgrade gdal31-libs-3.1.3-2.rhel8.x86_64 to  gdal31-libs-3.1.3-1.rhel8.x86_64. The raison was postgis_full_version return error Message :
        ERROR:  could not load library "/usr/pgsql-12/lib/rtpostgis-2.5.so": /usr/gdal31/lib/libgdal.so.27: undefined symbol: GTIFGetGCSInfoEx
I can precise dnf list installed | grep gdal show :
        gdal30-libs.x86_64                            3.0.4-4.rhel8                                     @pgdg-common
        gdal31-libs.x86_64                            3.1.3-1.rhel8                                     @pgdg-common
Have a nice day and thanks for your help.
Alain.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201106/5c4de600/attachment.html>
