[postgis-users] ST_3dintersects returns false for linestrings pairs with touching vertex
Alexandre Neto
senhor.neto at gmail.com
Fri Nov 13 13:20:12 PST 2020
Hi Nicklas,
Sorry, I just saw this now.
I am glad I was not crazy :-p
Thanks for your work.
Alexandre Neto
A sexta, 13/11/2020, 12:41, Nicklas Avén <nicklas.aven at jordogskog.no>
escreveu:
> I filed a ticket and a Merge Request
> https://trac.osgeo.org/postgis/ticket/4790
> ATB
> Nicklas
> On 11/13/20 8:18 AM, Nicklas Avén wrote:
> Hi Alexandre
> This seems to be a bug caused by some floating point error or some mis
> handling of the coordinates.
> In 3D the intersects function just wrapps ST_3DDistance and checks if it
> returns 0.
> So when trying with the same geometries with ST_3DDistance instead it
> returns 3.638977870632214e-12
> I will take a look at it.
> Could you please file a ticket?
> ATB
> Nicklas Avén
> On 11/12/20 2:46 AM, Alexandre Neto wrote:
> Hi,
> I am having a strange issue with st_3dintersects. I have two linestring
> that share the same end vertex. Nevertheless, using ST_3dintersects returns
> false.
> SELECT ST_3dintersects(st_geometryfromtext('LINESTRING Z
> (-27922.1593 -110233.7616 147.2259,-27928.084 -110230.8462
> 147.3629,-27930.6374 -110229.9248 147.3629,-27931.6207 -110229.587
> 147.3094,-27932.3841 -110229.275 147.3676,-27933.1861 -110228.9467
> 147.4365,-27937.0309 -110227.3638 147.7729,-27937.7892 -110227.0474
> 147.8412,-27938.6259 -110226.6885 147.9075,-27939.4617 -110226.3287
> 147.9663,-27943.6905 -110224.5169 148.2353,-27944.5442 -110224.1538
> 148.2687,-27945.6634 -110223.6871 148.2849,-27946.7835 -110223.2224
> 148.2982,-27952.3498 -110220.9011 148.3594,-27953.4568 -110220.4353
> 148.3756,-27966.8502 -110214.6482 148.7361,-27969.516 -110213.4996
> 148.7961,-27972.1805 -110212.3494 148.8566,-27974.1264 -110211.5032
> 148.9768,-27975.4229 -110210.9441 149.0093)'),
> st_geometryfromtext('LINESTRING Z (-28001.1829 -110201.8973
> 149.4396,-28000.3665 -110199.7073 149.3765,-27995.4183 -110201.8041
> 149.3354,-27975.4229 -110210.9441 149.0093)'))
> Any idea what could be happening in here?
> Thanks,
> Alexandre Neto
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201113/8602e1ea/attachment.html>
