[postgis-users] join multiple tables by id, and select all
Hugues François
hugues.francois at inrae.fr
Thu Nov 19 03:29:05 PST 2020
Sounds more like a general PostgreSQL question rather than a PostGIS one.
However, I guess you could build the list of unique variables as a string using queries on catalog tables embbeded in a PLPG function (or any other language depending on your work environment).
Regards,
Hug
De: "Shaozhong SHI" <shishaozhong at gmail.com>
À: "PostGIS Users Discussion" <postgis-users at lists.osgeo.org>
Envoyé: Jeudi 19 Novembre 2020 11:08:17
Objet: [postgis-users] join multiple tables by id, and select all
Hi, I tried the following for joining multiple tables by id, and select all into a new table.
However, it will not work because id gets repeated. How to select all except one column?
select a.*, b.*, c.*, d.*
into new_table
from a_table a
join b_table b on [ http://a.id/ | a.id ] = [ http://b.id/ | b.id ]
join c_table c on [ http://a.id/ | a.id ] = [ http://c.id/ | c.id ]
join d_table d on [ http://a.id/ | a.id ] = [ http://d.id/ | d.id ]
Looking forward to hearing from you.
Regards,
David
[Fichier texte:ATT00001]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201119/27f47d75/attachment.html>
