[postgis-users] Problem raster2pgsql on Centos 8 -postgres 12 / postgis 2.5
Alain Benard
alain.benard at inrae.fr
Thu Nov 19 07:32:01 PST 2020
Date: Fri, 13 Nov 2020 23:53:00 +0000
From: Devrim Gündüz <devrim at gunduz.org<mailto:devrim at gunduz.org>>
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org<mailto:postgis-users at lists.osgeo.org>>
Subject: Re: [postgis-users] Problem raster2pgsql on Centos 8 -
On Mon, 2020-11-02 at 08:17 +0000, Alain Benard wrote:
> I have a problem with rasterpgsql with all file geotiff.
> On a server Centos 7 / Postgres 9.5 / postgis 2.5 :
> /usr/pgsql-9.5/bin/raster2pgsql -b 1 -I -C -F -t 50x50 -s 2154
> filename.geotiff tablename > script.sql : it's OK.
> On a server Centos 8 / Postgres 12 / postgis 2.5 : (with the same
> geotiff file)
> /usr/pgsql-12/bin/raster2pgsql -b 1 -I -C -F -t 50x50
> -s 2154 filename.geotiff tablename > script.sql : error The
> script.sql file is not completed and the error is :
> free(): invalid pointer Abandon (core dumped)
Can you please fully update the packages? It should pick up PROJ 7.2.0, GDAL 3.2.0, etc. This was a RPM packaging issue, and should be fixed now.
Also, can you please remove OS-supplied PROJ packages as well?
dnf remove proj-*
Regards,
Devrim Gündüz
on 16/11/2020 I wrote :
In my case the problem persist. Perhaps i use an other depot.
For installing postgres postgis on a new virtual machine with Centos 8 i use a script:
(https://computingforgeeks.com/how-to-install-postgresql-12-on-centos-7/)
(https://computingforgeeks.com/how-to-install-postgis-on-centos-8-linux/)
The principals commands are :
dnf -y install https://download.postgresql.org/pub/repos/yum/reporpms/EL-8-x86_64/pgdg-redhat-repo-latest.noarch.rpm
dnf -qy module disable postgresql
dnf -y install postgresql12-server postgresql12-devel postgresql12-contrib
dnf -y install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm
dnf config-manager --set-enabled PowerTools
dnf -y install postgis25_12 postgis25_12-docs postgis25_12-utils postgis25_12-client
Two version of proj are installed with the script (even if i erase proj before with ' dnf remove proj-*') :
dnf list installed |grep proj
proj.x86_64 6.3.2-4.el8 @epel
proj72.x86_64 7.2.0-1.rhel8 @pgdg-common
The result : I can't use 'CREATE EXTENSION POSTGIS' :
ERREUR: n'a pas pu charger la bibliothèque « /usr/pgsql-12/lib/rtpostgis-2.5.so » : /usr/gdal32/lib/libgdal.so.28: undefined symbol: GTIFGetGCSInfoEx
Thank you for explaining.
Alain.
Today (18/11/2020) I try to reinstall on a new virtual machine with Centos 8.
dnf upgrade
dnf install dnf-plugins-core
dnf install postgis25_12
I created a database and ‘CREATE EXTENSION POSTGIS ;’ failed :
ldd /usr/pgsql-12/lib/rtpostgis-2.5.so |grep proj
libproj.so.19 => /usr/proj72/lib/libproj.so.19 (0x00007ff4cfa59000)
libproj.so.15 => /lib64/libproj.so.15 (0x00007ff4c08c5000)
It’s easy to reproduce this problem. The repository is corrupted and it’s impossible to install from it. I don’t know if this problem take a response on this list but we have some server without update because of this problem.
Thanks for advance.
Alain.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201119/627d87a2/attachment.html>
