[postgis-users] Forcibly parallelizing very expensive st_unaryunion in sequential scan on 20 row MultiLineString Table
Andrew Joseph ap.joseph at live.com
Thu Nov 26 12:20:30 PST 2020
I need to union chunks of MultiLineString together efficiently before feeding each chunk to st_polygonize. I know that the st_union aggregate function does not parallelize the actual cascaded union operation; therefore I collected the MultiLineStrings into a table of GeometryCollections where each row is 20 MB each with roughly 20 rows in the table.
I then set the table for maximum parallelization on sequential scan via
ALTER TABLE linework set (parallel_workers = 8);
And I then execute the simplest possible query in order to maximize parallelization:
set local effective_cache_size = '30GB';
set local maintenance_work_mem = '2GB';
set local default_statistics_target = 100;
set local random_page_cost = '1.1';
set local effective_io_concurrency = 200;
set local parallel_tuple_cost=0;
set local parallel_setup_cost = 0;
set local max_parallel_workers_per_gather = 8;
set local max_parallel_workers = 8;
set local max_parallel_maintenance_workers = 4;
set local min_parallel_table_scan_size = '1kB';
SELECT st_unaryunion(geom,.01) from linework;
As EXPLAIN ANALYSE shows, I do indeed get the maximum possible parallelization, however the query still takes  the exact  same amount of time it takes as if executed sequentially:
Gather  (cost=1000.00..5113.59 rows=1270 width=32) (actual time=13618.949..182565.567 rows=19 loops=1)
"  Output: (st_unaryunion(geom, '0.01'::double precision))"
  Workers Planned: 8
  Workers Launched: 7
  ->  Parallel Seq Scan on linework  (cost=0.00..3986.59 rows=159 width=32) (actual time=1702.296..22820.584 rows=2 loops=8)
"        Output: st_unaryunion(geom, '0.01'::double precision)"
        Worker 0:  actual time=0.002..0.002 rows=0 loops=1
        Worker 1:  actual time=0.002..0.002 rows=0 loops=1
        Worker 2:  actual time=0.001..0.001 rows=0 loops=1
        Worker 3:  actual time=0.001..0.002 rows=0 loops=1
        Worker 4:  actual time=0.001..0.001 rows=0 loops=1
        Worker 5:  actual time=0.002..0.002 rows=0 loops=1
        Worker 6:  actual time=0.002..0.002 rows=0 loops=1
Planning Time: 0.072 ms
Execution Time: 182565.628 ms
So it looks like postgres is scanning the table in parallel but for some inexplicable reason running the massively expensive function AFTER the gather which completely defeats the purpose of a parallel scan! Perhaps something related to TOAST tables? Again this is st_unaryunion, not st_union so I am perplexed as to why this is failing to work as intended. St_unaryunion is the only function in the entire query and is thus the only thing that can possibly be parallelized -and yet it isn’t despite 7 workers being spawned.
I also tried manually plitting the query up via UNION ALL:
SELECT st_unaryunion(geom,.01) FROM linework where chunk_id =1
UNION ALL
SELECT st_unaryunion(geom,.01) FROM linework where chunk_id =2
UNION ALL
SELECT st_unaryunion(geom,.01) FROM linework where chunk_id =3
UNION ALL
SELECT st_unaryunion(geom,.01) FROM linework where chunk_id =4
which also somehow manages to execute sequentially.
How can I force the query planner to do the sane thing and distribute st_unaryunion function on each chunk to CPU cores evenly? This seems like it should be possible for such a simple query on a small number so rows. I know I could try using smaller chunks, but that would create other performance problems not related to this query.
POSTGIS="3.1.0alpha3 b2221ee48" [EXTENSION] PGSQL="130" GEOS="3.9.0dev-CAPI-1.14.0" PROJ="7.2.0" LIBXML="2.9.4" LIBJSON="0.12.1" LIBPROTOBUF="1.3.1" WAGYU="0.5.0 (Internal)" TOPOLOGY
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201126/d61a5bc1/attachment.html>
