[postgis-users] ssl connection has been closed unexpectedly
Giuseppe Broccolo
g.broccolo.7 at gmail.com
Mon Nov 30 08:25:11 PST 2020
Hi David,
Il giorno dom 29 nov 2020 alle ore 01:20 Shaozhong SHI <
shishaozhong at gmail.com> ha scritto:
> Hi,
> I keep getting the following error when I use engine =
> create_engine(logging in details to postgres)
> df.to_sql('table_name', and etc.)
> OperationalError: (psycopg2.OperationalError) SSL connection has been
> closed unexpectedly
> (Background on this error at: http://sqlalche.me/e/13/e3q8)
> closed unexpectedly
> Can anyone shed any light on this?
This question is not really related to PostGIS, anyway...
Looks like you are trying to persist a Python Pandas dataframe into a
PostgreSQL table using
SQLAlchemy as driver. You are omitting to specify the connection string you
used to create the engine
that needs to be passed into the to_sql() Pandas' method, but the issue is
probably there:
the OperationlError exception is generally raised when SQLAlchemy is not
able to open a proper connection
to the DB.
Giuseppe.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201130/8ba09350/attachment.html>
